2004 Reaches 200,000
Discussion in 'Gen 2 Prius Main Forum' started by Stilview, May 27, 2009.
  1. Stilview
    Stilview New Member
    61
    Northern VA
    Purchased new in April 2004, hit 200,000 on 27 May 2009. Oil change/tire rotation every 5k, water pump at 120k, MFD replaced sometime after warranty (Toyota goodwill), on third set of tires (second set of HydroEdge), rear brakes replaced at 195k (still on original front), serpentine belt, right heel has worn a hole in the drivers side floor mat, using a quart every 5k, a few taillight bulbs, no change in fuel mileage.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,191
    Nixa, MO
    Using a quart of oil every 5k!! That surprises me a bit I have to say. Other than that it sounds like you're doing great.
  3. Stilview
    Stilview New Member
    61
    Northern VA
    I was surprised by the oil use, too. Just noticed it and will be keeping an eye on things. No drops in the garage anyway.
  4. a priori
    a priori Canonus Curiosus
    3,083
    407
    23
    Chicagoland (West)
    Wow! Congratulations!!
    You say your mileage has stayed the same, but how about the battery behavior? Are you in the green most of the time, or does it behave much like it did five years ago?
  5. dogfriend
    7,512
    1,185
    Carmichael, CA
    That really isn't that bad at 200k. Long ago, a coworker bought a Chevy Cavalier and the dealer tried to convince her that a quart every 1500 miles was normal.
  6. wayfarer72
    wayfarer72 New Member
    Denver, CO
    Congrats! It's good to hear that someone has really gotten their money's worth out of our favorite car.
  7. yardman 49
    yardman 49 Active Member
    606
    77
    Northern Kentucky
    1 quart every 5k miles at 200k miles on your Prius seems good to me,also.
    Our brand new 2001 VW Beetle used to use 1 quart every 1000 miles! VW considered this to be normal!
    I am so glad that car met with an untimely end!
  8. dogfriend
    7,512
    1,185
    Carmichael, CA
    Yes, in fact, our litigious friends at ConsumerAffairs.com have a page on VW oil consumption:
    Consumer complaints about Excessive Oil Consumption in the VW 2.0 Liter Engine
  9. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    I'm confused, I thought the Prius uses around 3 quarts? What does 1 quart every 5k mean?
  10. dogfriend
    7,512
    1,185
    Carmichael, CA
    Additional oil added between changes. I think most Prius owners do not have to add any oil between 5k Oil Change Intervals. I have yet to see the level drop on the dipstick with almost 30k on my car.
  11. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    So if they change oil every 5k, then do they add 1 quart after say 3k? and then when they reach 5k, they change out the oil again?
  12. dogfriend
    7,512
    1,185
    Carmichael, CA
    Yes, its been awhile since I've owned an oil burner, but that would be typical.
    BTW, the owners manual for the Prius recommends checking the oil level during every refueling. However, I only check every 2nd or 3rd time because I haven't seen it drop yet.
  13. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    The 2nd that I'm aware of over 200K. A friend who purchased both a Gen 1 and a Gen 2 from me is now waiting impatiently for his Gen 3 to arrive. His Gen 2 purchased in Jan 04 is currently at 242,000 miles.
    His report of maintenance issues is very similar. Serpentine belt at about 180,000 miles and brakes at about 225,000 miles. This week he was still getting 50 mpg on highway trips in good weather. It may need shocks and/or struts if it was going to be driven much further.
  14. dogfriend
    7,512
    1,185
    Carmichael, CA
  15. xsmatt81
    xsmatt81 non-AARP Member
    522
    Vegas
    I don't know I've never owned a car past 80,000 miles..it was an Escort, I had to add oil here and there, and I really did not take that great care of it. Most 4 cylinders are very easy on engine oil. V8 on the other hand drink motor oil like a dry drunk on a binge.
    i take care of my fathers 2004 Town car that mainly sits in the garage while he is away on jobs, I will drive it sometimes and my mother..she can go on a tank of gas for a whole month or more.....anyway I have to add oil in between changes, usually a quart or more to keep it up to the mid-full mark on the dip stick. This more common in larger block motors of course
    your engine is just old I guess, probably would be a good idea to have seals, etc checked...even with that mileage a quart seems excessive. But I'm no expert.
  16. dogfriend
    7,512
    1,185
    Carmichael, CA
    Also more common in Fords than Toyotas. :madgrin:
  17. xsmatt81
    522
    Vegas
    Right from what I understand American motors have a fetish for oil in large amounts.
    Most 4 cyn though will barely eat through oil. My old Elantra could go 7500 miles and just be in the middle of the dipstick.
    the prius I don't know, because I always change it @ 5k,it's always at the same full level..
    that old escort I had ran really well, just needed oil top off's from time to time, it wasn't much worse though than the import on oil.
  18. dogfriend
    7,512
    1,185
    Carmichael, CA
    My worst oil burner was a 74 Ford Courier (aka Mazda) pickup, about 1 qt per 500 - 600 miles. My dad used to have a 68 Chevy Pickup that burned so much oil he stopped changing it, he would just add more when needed.
  19. jdenenberg
    jdenenberg EE Professor
    3,831
    1,824
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My 2004 Prius is ONLY at 150,000. Oil changes at 5k (synthetic, no loss between changes yet). At 60k and 120k changed ATF (Type WS tranny fluid), At 100k changed both coolant loops, plugs, and PCV valve. Still on the original MFD! Just started the fourth set of tires (now Nokian WRg2, better MPG than HydroEdge but only 50k tires) and still on the original brakes. Yes there is a heel hole in the driver's floor mat. and replaced both taillight bulbs recently. Will probably replace BOTH coolant pumps and the serpentine belt soon as the coolant needs to be changed again at 150k. My MPG is creeping up as the Nokian tires (WR first, now WRg2) get better MPG than the Integrity and Mchelin MXV4 that came first.
    These are GREAT cars.
    JeffD
  20. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Wow! Congrats! You sure bought the right car!
