2004 Won't go into Drive
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by krousdb, Jan 3, 2010.
  1. krousdb
    krousdb NX-74205
    581
    500
    47
    Raleigh, NC
    This morning when I when to go for a drive, my 04 wouldn't go into Drive. Instead it goes into neutral. I tried powering on and off several times to no avail. I did notice that the brake light was on. The same thing happened a few days ago but the brake light went out after I pumped the brakes a few times. The previous time the temp had dropped below freezing and last night we had a hard freeze. My guess is that I have water in my brake system and I am being prevented from placing the car in drive because of that. Can someone confirm that frozen water in the brake line could cause this problem? Is it as simple as replacing the brake fluid or might there be a part that is bad? 192k miles, original brake fluid.:eek:
  2. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Beautiful reasoning. I hope you are right, and the fix is easy and inexpensive.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    Since your mentioning brake pedal/brake light issues I thought in addition to the brake pedal switch on the back of the brake pedal there's also another switch there thats tells the ECU that the brake pedal is indeed pushed all the way down and then will allow the ECU to shift into D when commanded. But my Chiltons does not mention another switch. Just a rudimentary adjustment of the brake light switch which the ECU must also use for trans shifting.
    That adjustment is to lengthy to post here and most end with the dealer scan tool neeeded but pick up a Chiltons and check it out.
    It may be as simple as that.
    I do know there's a lot of brake sensors there and any possible malfunction of the brake system as you mentioned would clearly throw a DTC so I doubt the water but I would at least have the dealer change the brake fluid asap as you are way overdue.
    BTW, brake fluid change is not a DIY in your driveway deal. You can't bleed the system without Toy's scan tool system. In fact if you open the hydraulic system it will immobilize your car and result in a FB tow to the dealer. The brakes are really involved on our cars. We have:
    Pedal stroke sensor
    Steering angle sensor
    Skid control ECU
    Pedal stroke simulator
    Wheel cycinder pressure sensors
    Wheel speed sensors
    Brake actuator
    Yaw & deceleration sensor
    Yikes...
  4. Patrick Wong
    18,210
    6,514
    A few questions for you to consider:
    1. Is the car READY?
    2. When you say brake light, are you referring to the red BRAKE light (or the amber circle with !)? Any other warning lights on, such as ABS or VSC?
    3. Do you hear a warning sound when the car refuses to shift into D?
    4. What happens if you hold the shift lever in the D position without allowing it to return to the resting position?
    5. Has the 12V battery been replaced, and if so, when?
    6. Since your car is a PHEV conversion, is it possible that there is a fault with the conversion which results in the symptoms that you noticed?
    Assuming that we are talking about the red BRAKE light coming on, what is the fluid level in the brake fluid reservoir? If there's no obvious issue, then the appearance of that light means that the hydraulic braking system is impaired and mandates an immediate dealer visit (if/when you can get the car into D) as the car is not safe to drive in that condition.
    Brake fluid is hydrophilic, so it will mix with any water that happens to find its way into the system, which results in a reduced boiling point for the brake fluid. I doubt that is the cause of your problem.
    Regarding your not being able to shift into D, my guess is that the shift selector mechanism is faulty and has to be replaced. Maybe the transmission control ECU thinks you are trying to shift from P into B instead of D, and this is not allowed. The ECU will shift into N instead.
  5. krousdb
    krousdb NX-74205
    581
    500
    47
    Raleigh, NC
    Yes, it is the red brake light along with the 4 yellow lights which include VSC. Didnt notice if ready was on. I dont have the car with me to check anything else. New battery a few months ago. The PHEV conversion has been running without problem for over 10000 miles. I dont see that as an issue. I think the problem is related to the freezing temps. I will check back when I find the cause.
  6. Patrick Wong
    18,210
    6,514
    Well, if the car is not READY, then clearly it will not shift into D.
    If you can make the car READY and all of those lights are on, then I would say the problem is more likely to be that the DC/DC converter within the inverter is not producing 13.8VDC, so the skid control ECU is having a fit.
  7. bogeybob513
    bogeybob513 rtc513
    147
    Myrtle Beach, SC
    I had a similar problem. There was also a red led in the center of the power button. A lot of other posts point to the emergency brake light switch. I put the emergency brake on, then off, and it solved the problem.
  8. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    First...listen to Patrick...he knows more than I do.
    But I hear this and IMO it's fairly simple.
    If you're in Ready then it's probably not the brake pedal sensor/switch.
    If it's not going into Ready then I would suspect the switch as it's a known problem and if faulty the car won't think you're depressing the brake pedal and thus won't go into Ready.
    If in Ready then the shifter itself may be the next most likely culprit as they are also known to fail...fortunately it's a cheap/easy fix to replace.
    Failing those things I return to my original advice...listen to Patrick.
  9. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Evan's reasoning is sound.
    Tom
  10. Sandy
    Sandy Hippi Chick
    860
    53
    Ocala,Fl
    12V same thing happened to mine:)
  11. krousdb
    krousdb NX-74205
    581
    500
    47
    Raleigh, NC
    Hey Bob, I tried the emergency brake several times to no avail. I see you are in Myrtle beach. That is where my car is currently stranded. I'm headed back there tonight to see if the Ready light comes on. Did you get your car at Sparks Toyota? Can you recommend them for service?
    Thanks,
    Dan
  12. rjsailnsd
    rjsailnsd New Member
    Escondido, CA
    I had these problems and it was because the starter battery was not holding charge. I could get the car to start if I turned off all interior lighting, radio and climate control, reset the computer by disconnecting the negative terminal of the 12V battery for a few minutes, reconnect the terminal, turn off the smart key mode and insert the key fob directly into its spot below the dash board. Push the start button once, push the park button once , engage the parking brake and then push the start button . Car would start and I could measure 13.85 volts DC at the 12 volt battery posts. In my case the 4 year old battery was done and getting a new one was the trick . Have you checked the Voltage on the battery? The on board computer needs 12 volts otherwise it is a mess and will not let you get into drive mode. Even new batteries can discharge. 12 volts is a must.
  13. richard schumacher
    7,682
    1,062
    United States
    Note that when the car is in Ready (ON), the voltage at the terminals and the jump point is essentially the output of the DC-DC converter, not the output of the battery. To measure the unloaded battery the car must be OFF, or in ACC to measure the battery with a modest load (headlights, etc.).
    For the built-in battery test procedure see
    http://priuschat.com/forums/newbie-forum/73400-weird-stuff-happening-mpgs-dropping-test-battery.html
    If the battery is too close to dead the self test won't work.
  14. krousdb
    krousdb NX-74205
    581
    500
    47
    Raleigh, NC
    OK, so there is NO Ready light and the scan gauge says 11.4V. I guess my 4 month old Optima Yellow Top is dead. I guess I will put in the original OEM 12V. iT NEVER GAVE ME A PROBLEM.
  15. Patrick Wong
    18,210
    6,514
    Thanks for the update, hope you have a chance to charge up the original 12V battery, before you install it.
  16. bogeybob513
    bogeybob513 rtc513
    147
    Myrtle Beach, SC
    Yes, they are reliable, but did over fill the oil change twice, even after the service guy wrote in big letters "DO NOT OVERFILL!".
    I THINK PATRICK IS RIGHT-THE SWITCH HE IS TALKING ABOUT IS BY THE FOOT BRAKE PEDAL, NOT THE EMERGENCY BRAKE.
    Good Luck!
  17. qbee42
    18,058
    3,081
    Northern Michigan
    It's part of the same switch assembly that runs the brake lights. While mechanically linked, the same electrical contacts do NOT run the brake lights - in other words, functioning brake lights do not guarantee a working switch assembly.
    Tom
  18. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    What does the ScanGauge read usually? I am interested because yesterday when I checked the battery with the ScanGauge it was 11.9V with the car OFF and 11.1V in ON mode with headlights ON. Someone posted that these readings may be 0.7V lower than actual. Yes at some point I need to dig up my multimeter...
  19. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I read 0.7V lower on the Vehicle Service Menu than I did at the actual battery terminals and the jumper bar under the fuse cover. So, I would recommend actually reading the voltage at the battery terminals with a multimeter, to verify the readings that you are seeing on other devices, before trusting them. Especially if you plan to make a decision on whether to replace the battery or not.
