2005 135K Miles Traction Battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by FuelMiser, Jul 20, 2014.
  1. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    So our car has performed flawlessly since 2005/135K miles. Still getting 55 mpg in the display in the summer, 45 mpg in the winter. Only issue is traction battery SOC quickly goes to full green when coasting downhill, and 1 or 2 purple bars when climbing. In Colorado, this happens a lot. Within a mile or so coasting downhill the SOC is full green. Question is: should I replace the traction battery? Is there any harm to continuing to experience this behavior? When full green, I realize I am using friction braking over regen braking, have actually felt the crossover from regen to the pads, as the SOC goes full green. I understand dealer replacement is almost $3,000. Car is flawless other than this behavior. I am not DIY, so not interested in rebuilt. Opinions?
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    You are not damaging any other part of the car, so you can drive until the big triangle lights up.
    It is a nine year old car, consider a used ($900) or re-manufactured ($1500) battery.
    Try B when going down hill.
    #2 JimboPalmer, Jul 20, 2014
    FuelMiser likes this.
    52,807
    if your still getting good mpg's, i wonder how much time you have on the current battery?
  4. Patrick Wong
    18,210
    6,517
    No.
    No.
  5. FuelMiser
    1,349
    929
    Monument, CO
    Thanks for the replies! This is what I figured. Keep going until failure...
