2005 flasher unit
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ogsimmons, Feb 4, 2009.
  1. ogsimmons
    ogsimmons New Member
    Temecula, CA
    I wish to add LED to signal lights but I was told it would mess up the flasher speed. Anyone know what flasher I would require to support LED signal lights?
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    See my answer to your post on PriusOnLine...
  3. maseace
    maseace Prius enthusiast
    191
    Poulsbo, WA
    If you're ok with it blinking 3x faster than normal, no flasher is needed. I don't think there is a load-independent flasher available that fits the Prius. You would probably have to go with load resistors. They are simply high wattage resistors that hook up near each turn signal bulb that trick the flasher into thinking that a regular bulb is there when the turn signal is on. The places that sell LED bulbs usually have load resistors for sale.
  4. ogsimmons
    Temecula, CA
    Thanks for your help I will contact V-LEDs for the load resistors.
    Dale
