2005 Prius had a flat--went into Limp Mode. Got new tires, but gas mileage is BAD...?
Discussion in 'Newbie Forum' started by Dlphnlvr4, Aug 11, 2013.
  1. Dlphnlvr4
    Dlphnlvr4 Junior Member
    A couple of weeks ago I had a flat on the Interstate. They were doing construction, and I had to drive about 1/4 mile to get off the road. I replaced the flat with the donut...which was low in pressure. The car went into Limp mode. I got air in the donut and drove it "gently" home (10 miles).
    I took it straight in and got new tires--Firestone Affinity Touring.
    Now my gas mileage (on my regular driving route) is 10--15 miles lower! I checked the air pressure, and added up to 38 psi.
    The car seems to have more resistance, and I can't seem to get the engine to "rest" while driving...not like before.
    Does the limp mode need to be reset?
  2. sevlillevik
    sevlillevik Junior Member
    44
    Puyallup, WA
    That is too bad about the flat tire. I hate it when that happens. What is the limp mode? Perhaps it needs to be reset. That is strange that the gas mileage is way down then before. I have had a total of four flat tires on my 2010 prius. (we'll say that I am getting good use out of the donut). I have never noticed a decrease in my gas mileage at all, except when it is cold, which is normal. Is there extra tread on the new tires?
  3. Dlphnlvr4
    >>Not that I know of...just NEW. The Limp Mode is when the car will not go over 35 mph if it senses something is wrong.
  4. JimboPalmer
    12,442
    6,836
    Greenwood MS USA
    I do not see that Firestone Affinity Touring are Low Rolling Resistance tires, so they may never have as good as MPG as the OEM tires.
  5. Dlphnlvr4
    >> The Affinity Touring is supposed to be low rolling or high mileage...that's why I bought them. The tires I took off were WalMart Goodyear Vivas.
  6. mikefocke
    3,353
    1,466
    Sanford, NC
    Tires exact same sizes?
  7. ursle
    ursle Gas miser
    1,049
    191
    NH
    Last tire change on my '06 the tech ripped a tire so I only had 2 mounted, had to go back the next day, as the new tires were much larger then the old once I went over 32 the ice would stop, limped home, next day with the 2 new same sized tires the limp mode went away and had no reflection on future mileage, yer problem is rubber, and or an emergency brake rubbing :)
  8. Dlphnlvr4
    >>Yes...same size.
  9. Boston2008Gen2
    Boston2008Gen2 Junior Member
    59
    Houston TX
    I bet your new tire has lots of resistance and sticks to the road which is causing the mileage drop. This happened with me too. With my original tires (Good year), I was getting 53mpg. At 55k, I got Hankook Optimo H727, mileage dropped to 48. Now I am at 80k, still get 48.
    Its definitely the tire. I am going to change my tires to LR atleast the fronts.
  10. SteveLee
    SteveLee Active Member
    634
    173
    North Carolina
    I
    High mileage is not the same as LRR. I also don't see any indication the Affinity is a LRR tire. If not, lower MPG is to be expected.
  11. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    505
    Neb
    Plus they're brand new and need to be broken in a while...
  12. Dlphnlvr4
    Update...After 2 1/2 weeks, and increasing the tire pressure, the mileage is better. The sticker on the door recommends 35/32. The tires Max pressure is 44 psi. We increased the pressure to 42/4o, and started getting about 47 mpg--which is within 2 mpg of what we were getting before with the Goodyear Viva 2 tires. (Those Viva 2 tires were very cheaply made though. We had already replaced one for a belt separating, then the next one blew out and split up the side!)
  13. Drdiesel
    Drdiesel Active Member
    585
    152
    Monterey CA
    :ROFLMAO: :ROFLMAO: :ROFLMAO: Not :confused:
  14. 510bg
    510bg Member
    142
    How is limp mode activated? Do you get a display in the console?
  15. Mr Incredible
    955
    505
    Neb
    Unbeliever.
    Common knowledge, duh...
  16. ursle
    ursle Gas miser
    1,049
    191
    NH
    The computers see one tire flat or low on air and kill the ice at 32mph, don't remember any icons on the dash, didn't look, was busy keeping on keeping on. Limp mode is exactly like stability control, the car is controlling itself, not allowing you to damage "it", actually, I vaguely remember the stability control light on while it was in limp mode, perfectly drive-able below 32mph.
  17. Drdiesel
    585
    152
    Monterey CA
    Smoke em if ya got em (y)
Loading...
