2005 Prius loud engine
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by FrugalMan, Oct 23, 2018.
  1. FrugalMan
    FrugalMan New Member
    Does anyone know what this sound is? It does it all the time warm or cold.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    Sounds like a g2 Prius to me. What are you concerned with the sewing machine sound of the valve train?
    That’s normal the car uses solid lifters very very noisey top end. Use 10-30 weight oil thAt will help a little,
    I run a 40 weight high performance oil that really helps make that sound less clakity.
    Car must be new to you.
