2005 Prius put itself into neutral and gave a bunch of lights??
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jessika, May 13, 2016.
  1. Jessika
    Jessika New Member
    Northern Kentucky
    This morning on my way to work by car went into neutral and shut off while driving. The hybrid warning system light came on along with the malfunction indicator. The master warning light also came on. Has anyone had this happen? I would like an idea of what it could possibly be before going to Toyota. Also the car turned back on eventually... should I have it towed or should I drive it there?
  2. S Keith
    S Keith Senior Member
    799
    327
    AZ
    2003 Prius
    Something broke.
    Read codes. Options in my sig.
    Drive it at your own risk.
    Jessika likes this.
  3. JC91006
    16,470
    8,383
    If I had to guess, it would be your car has a failed inverter coolant pump. It overheated and shut down. As it cooled, you were able to start it again.
    I would not drive it a long distance. Repair cost would be around $500.
    But this is just a guess........
    Jessika likes this.
  4. Jessika
    Jessika New Member
    Northern Kentucky
    Something only toyota should fix? Or any repair shop?
  5. JC91006
    16,470
    8,383
    Any knowledgeable shop can do it. There is a recall on the part.......if you haven't done the recall before, it'll be free with Toyota
  6. Jessika
    Jessika New Member
    Northern Kentucky
    Great! Thank you!
  7. bisco
    48,971
    welcome to priuschat! how many miles on her?
    Jessika likes this.
  8. Jessika
    Jessika New Member
    Northern Kentucky
    Thank you~ She has 219,587
    Called Toyota and the inverter coolant/water pump was replaced in 2011
  9. bisco
    48,971
    wow! how old is your 12v battery?
  10. Jessika
    Jessika New Member
    Northern Kentucky
    50,000 on it
  11. bisco
    48,971
    years is more important, but it might be worth testing, it's quick and easy.
    at 220k, it could easily be the hybrid battery though.
  12. Jessika
    Jessika New Member
    Northern Kentucky
    than you. She goes in Tuesday
  13. bisco
    48,971
    please let us know how you make out, all the best!(y)
  14. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,796
    Undisclosed Location
    I don't know how far away from the dealership you are, but I would highly recommend towing from a purely safety standpoint. Whatever the problem eventually is determined to be? Driving a vehicle that might put itself in neutral and shut down in traffic is never a good idea.
    Best of luck with the diagnosis, and hopefully it trends towards being an affordable repair. But as far as getting that diagnosis and getting it to the dealership, safety should be a priority.
    PS.
    Goes in Tuesday? And if it was me? I wouldn't drive it at all until AFTER diagnosis and repair.
