2005 Prius refrigerant oil help
Discussion in 'Gen 2 Prius Technical Discussion' started by statultra, Jun 12, 2006.
  1. statultra
    statultra uber-Senior Member
    796
    30
    Edison,NJ
    2001 Prius
    So i was reading about the ND11 oil required when i change my refrigerant ( salvage prius ), Where do you think i would go to get this type of refrigerant oil? i never heard of ND 11, mostly PAG and ND30 and ester oil.
    also, i recently installed my brand new seatbelts, and the SRS light is sstill on , do you think i should go ahead and replace the front airbag sensors ( i didnt replace them considering my airbags didnt pop )?
    thanks
  2. galaxee
    galaxee mostly benevolent
    9,810
    464
    MD
    go to the dealer and order the nd11
    center airbag sensor assembly (aka airbag computer) needs to be replaced. if there's a collision, whether airbags deploy or not, that has to be replaced.
