2006 Gen II, I think the hybrid battery just went.
Discussion in 'Gen 2 Prius Main Forum' started by kdmorse, Sep 6, 2016.
  1. kdmorse
    kdmorse Member
    205
    Germantown, MD
    Up until this year, I would have described my 2006 as 100% trouble free - the only maintenance it has required to date is disposable items (12v battery, tires, wipers, oil/filters, fluids). The little rubber cover on the hatch latch is coming off, but I see that's not uncommon. This year started with having to replace the HID headlights, not unexpected, but not cheap either.
    Last week the hybrid battery showed signs of being cranky. Friday it lit up the dash board, and was clearly struggling (all the regular HV Battery Failure symptoms). Decided not to temp fate and drive it around over the holiday weekend. Drove it to the shop today, wasn't sure I'd make it the 9 miles to get it in. (It was really, *really* unhappy).
    10 Years, 8 Months - so to a degree I was running on borrowed time. Now I'm waffling, because I was already thinking of replacing it in a year or two. How much do I want to put into it if I'm only going to keep it a couple of years. Do I commit myself to owning it for another 5 years. If I replace it, what do I want to replace it with. Waffle Waffle Waffle...
  2. JC91006
    16,470
    8,383
    How many miles on your car?
    If your timeframe of owning the car will be 3 years or less, you can buy a remanufactured battery from Dorman. They are sold through many auto parts retailers (Napa has 10% off if you have AAA card). That battery has a 3 year warranty (you'll probably need it), so it'll buy you some time.
    48,990
    this is a spectacular time to buy a gen4. people are getting unheard of deals, which may not be seen again for a long, long time.
  4. fotomoto
    fotomoto Senior Member
    5,597
    3,771
    So. Texas
    As bisco said, Toyota is pretty motivated to move Gen4's so you might get more money on trade than you think. If buying a new car is not an option right now, then consider going for a new Toyota battery. Yes it costs more but you'll get more back when you try to sell it on the open market (keep all records of course). If you have a ton of miles all ready, go for a cheaper rebuilt and cross your fingers.
  5. wjtracy
    wjtracy Senior Member
    11,314
    3,588
    Northern VA (NoVA)
    Keep in mind some folks call Toyota USA after the dealer assessment to ask for goodwill assist on battery replace. Sometimes you can swing a batt replacement deal on new Prius purchase if you have a need for 2nd car. Unclear chances but perhaps
  6. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    Before you get your heart set on that new Gen IV, you really should go down to the dealer and talk real numbers. I was all set to pull the trigger. Lo and behold the trade in value of our Gen III dropped like a rock in the last two months. We are talking over three thousand dollars. I am being told it is because of the new body style. All I know is KBB was saying our Gen III was trade in value of almost 17K sixty days ago and now with the options it is only worth 14K. The mileage really hasn't changed that much in the two months time, so either overall value of Prius has gone down due to the gas being cheap or the new Gen IV has really knocked down trade in values.
  7. jeff652
    jeff652 Senior Member
    597
    623
    Idaho
    Don't spend more than you need to! Recondition the existing battery and keep driving it for another few years. worst case you might have to replace a module or two. Whole thing will cost under $500 and only take a few days over a weekend:
    What causes hybrid batteries to degrade and fail? - Hybrid Automotive
    iron-icman likes this.
  8. kdmorse
    kdmorse Member
    205
    Germantown, MD
    I just ok'd a new battery. But I see what people mean when talking about good deals on 2016's, I saw quite a few *very* good ones floating around - but none of them had the packages I wanted. I'm one of those people that just wouldn't be happy knowing there were features out there I wanted - buying a new car that didn't have them - even if it's a good deal.
    So I'm going to fix up the 2006, but keep looking. Maybe I see a deal on a car I like, maybe I wait until this time next year when they're trying to get rid of the 2017's to make way for the 2018's. Maybe I keep the 2006 for 3 more years. I think I'll probably poke a few dealerships to see if they can find me a 2016 #4 with PCP+ATP, see if they make me an offer I can't refuse.
  9. bisco
    48,990
    all the best!(y)
  10. kdmorse
    kdmorse Member
    205
    Germantown, MD
    It's back, happy, and well behaved so far. For the record, 10 years 8 months - only 62K miles (Time got me, not distance traveled). I figure at almost 11 years, I was on borrowed time for an original traction battery (and an original set of nearly everything else, including brake pads) anyway.
    It threw (at the very least, I'm not sure every every battery cell code was transcribed for me):
    P0300 (Hybrid Battery Control)
    P0A80 (Hybrid Battery Malfunction)
    P3022 (Battery Cell R Weakness)
    C1241 (Ignition Circuit Open)
    C1259 (Regenerative Malfunction)
    C1310 (Hybrid Malfunction)
    U0126 (Steering Angle Communication)
    Check Engine Light, VSC light, Power Steering Warning (I think), and Master Warning were lit up. On the MFD, the indicated a hybrid systems fault - little car with an exclamation point in it. (I have seen some screenshots of a separate hybrid battery warning icon that can appear, I do not believe it appeared on mine). The battery cooling vent would come on within 5 minutes of starting the car. And steering was, odd.
    Comparing the car's behavior now, (how slowly and steadily the battery bar moves over time, and how the engine runs), it's clear that there were signs of issues for longer than I initially thought. They just happened gently enough that it didn't register that the battery indicator was moving faster and faster (and twitchier), and the engine coming on at unusual times more and more (as the degradation happened gradually), until the last week or two when it was obviously flaky. By the time I realized how fast it was going from blue to 1 purple, then working it's way back to 3 blue, then jumping to full green while running the engine 100%, falling to 3 blue if I faced a hill - it was probably in pretty bad shape. The final straw was probably me not going anywhere for 3 days (noticing that i put it away fairly blue, and woke it up 2 purple), throwing it in reverse, and driving a short distance - went back into drive with no bars, and next time I hit the brakes, it lit up and said enough was enough.
    The above all seems fairly consistent to me with a failing main traction battery.
    I limped it 8+ miles onto the shop on Tuesday. It's possible I shouldn't have (I'd be interested in opinions on that from both a safety, and 'additional damage' point of view if applicable). It was *really* unhappy. And four times on the way (facing a minor hill), it went into a state where it would rev, but would not accelerate. (Two of the events I think match what has been referred to as Turtle mode, I think the other two it put itself in neutral, it felt that way, I don't think I looked). Knowing it's state, I drove every minute of the trip with a plan for coasting the car somewhere safe if lost power, so I was in each case able to move to a side street and stop (at an angle where a Tow-Truck could easily get me). But it restarted each time with full power. Possibly a stupid trip, but by the time it exhibited it's first failure, I was past the half way mark, so I carried on. I already had a plan to get it tow'd if necessary, but to it's credit, it never left me stranded anywhere.
    Hybrid battery replaced. Brake work done (it was coming up anyway). Some minor engine maintenance. Stupid little rubber cover for the rear hatch released glued on (I see that's not an uncommon problem? What are others doing to fix it? It appears on first glance not to be an orderable part, and can only be obtained with a complete latch replacement (>$150) which is silly).
    Anyway, it's fixed and back in my hands. I am still looking at 2016's. I eventually found a few 2016 Four+PCP+ATP's in the area in acceptable colors and decent prices, but not prices i would jump at. Poked a few salesmen, if the cars in question are still on the lot in a week I may see how badly the want to get rid of them. Since I'm no longer in 'need' or antsy about being caress (one car household), I can be quite laid back about it all.
    Thanks for the input (and if this double-posts I apologize, the forum is being a bit twitchy)
  11. bisco
    48,990
    congrats!(y)
