2006 Prius - 62,000 miles - needing Hybrid battery replacement.
Discussion in 'Gen 2 Prius Main Forum' started by tsk0, Jun 22, 2016.
  1. tsk0
    tsk0 New Member
    Denver
    Hi All,
    I'm in Colorado and have 2006 Prius - that has just 62,000 miles. Recently lots of lights came on. The car itself was driving fine. I took it to Autonation Toyota Arapahoe and they said that the hybrid battery needs to be changed and it will cost $4100 to do this.
    There were some Factory Recall Service items that was over due also. So they said that they will do that.
    I told them that I will think about the battery and let them know. I went and picked up the car back from the dealer, now it is showing a red alert in the display info also and the car wouldn't accelerate as it was when I dropped the car to them. Seems to me that the dealer service guys did something to make sure that I get it back to them ASAP.
    Anyone in Colorado who has replaced the car battery for a 2006 prius? I guess I'm out of warranty as it has been more than 8 years. Considering the car's KBB value ( if the battery is good ) is only $7800, I don't want to spend $4100 to fix the battery.
    48,969
    welcome! shop dealers, so go as low as $2,500.
  3. JC91006
    16,470
    8,383
    I think you should pursue a goodwill warranty with Toyota corporate. Chances are they'll cover all of the repair costs because of your low mileage.
  4. jeff652
    jeff652 Senior Member
    597
    623
    Idaho
    You can read about how hybrid batteries degrade and fail here:
    Prolong Grid Charger FAQ - Hybrid Automotive
    If the dealer does not comp you a battery, odds are in your favor that performing a reconditioning will be enough to save the pack. Worst case you might need to replace a module or two. Either way it will be a lot less $$ than paying for a full battery replacement.
    #4 jeff652, Jun 23, 2016
  5. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    Being in Denver, go to Boulder Hybrids: Boulder Hybrids |
    They can get you a new pack ($2500 ish), a newer old pack ($1400-$1800) or a much older pack ($800). All prices are estimates trying from memory last I called them.
    You quite obviously don't drive very much. So for you, age will kill it. I would almost just get a cheap rebalanced pack and try to keep it balanced like grid charge or run it more often.
    If you have a very mechanically inclined friend, buy some a module on eBay and replace it for $30-$50. It is a temporary fix.
  6. jeff652
    597
    623
    Idaho
    Paul at Boulder Hybrids is one of our authorized resellers, I also highly recommend him. Ask him about Risk Free Reconditioning™ with Prolong Battery systems. He can share all the details but basically he can recondition your existing pack using our products and perform free or very low cost follow on maintenance to ensure your hybrid battery stays healthy. If this treatment does not work and the battery fails in the next couple years after the service is done, all of the reconditioning service cost will be applied toward a replacement battery pack.
  7. tsk0
    tsk0 New Member
    Denver
    Thank you so much for suggesting this. I called Toyota customer support and they negotiated with the dealer. Apparently I need to spend only $1600 for the battery. Waiting for the dealer to call me once they get the battery in stock.
    jeff652 likes this.
  8. JC91006
    16,470
    8,383
    Congrats!! Now hopefully you'll get another 10 years of trouble free driving.
