2007 key fob is in bad shape, how much of a hassle is replacement?
Discussion in 'Gen 2 Prius Main Forum' started by jimbokong, Jun 5, 2021.
Tags:
  1. jimbokong
    jimbokong New Member
    Oahu, HI
    I’ve had the same fob since I got the car, and in the last year or two the rubber covering the buttons has worn away completely, so the electronics inside are visible. I figure it’s probably a good idea to get a backup now just in case this one dies on me unexpectedly, how difficult/expensive is this process usually?
  2. PriusCamper
    PriusCamper Senior Member
    10,926
    4,427
    Pacific Northwest, USA
    For $10 you can get a new case: Replacement Car Key Fob Remote Shell Case For Toyota Prius 2007 2008 2009 3Bto | eBay
    It requires you to cut open the seam of your old fob with a razor blade and then put the electronics into the new case. Also don't forget the little tiny black rectangle-shaped RFID chip inside there. People too often forget that piece and lose the car's ability to sense when the fob is nearby.
    jimbokong, srellim234 and skittle021 like this.
  3. Kaptainkid1
    Kaptainkid1 Active Member
    308
    243
    Los Angeles
    Youtube and very easy to replace the covers. Buy oem if you can the knocks tends to be cheaper in material but my knock off has lasted a 2 years no problems.
    SM-A526U ?
  4. OBJUAN
    OBJUAN Member
    164
    74
    canada
  5. srellim234
    srellim234 Senior Member
    1,193
    1,681
    Laughlin, Nevada
    I replaced both of my fobs in November of 2018 with these from Amazon
    I also purchased these silicone sleeves to protect the hard plastic
    It's not difficult and not expensive.
    jimbokong likes this.
  6. jimbokong
    Oahu, HI
    Didn’t even think about this but it seems like the obvious solution now. Thanks!
    srellim234 likes this.
  7. srellim234
    1,193
    1,681
    Laughlin, Nevada
    You're welcome.
    Important notes:
    1. Make sure you get the correct fob. There is a difference between two of them. Get the one that has the same color Toyota logo on the back (either black or silver/chrome).
    2. As described above, make sure you also transfer the black RFID chip along with the little circuit board to your new fob.
    3. Transfer your old metal valet key to the new fob too. That way you don't have to deal with a locksmith cutting the blank one that comes with it.
    #7 srellim234, Jun 9, 2021
  8. qmanqman
    qmanqman Active Member
    297
    110
    CO
    By not paying close enough attention, I bought the rubber slip on by mistake. Works fine.
  9. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,783
    2017 Prius c
    Ask some locksmiths in your area.
    Not only can they probably sell you a "spare" FOB, they can sell you a new cover too.
  10. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    You should have a spare just in case. Far cheaper than if the 1 key you have gets lost or broken.
    Don]t forget to get the lockout key cut.
  11. Skibob
    2,912
    1,496
    Northern California
