2007 Prius C1259/C1310 Brake Actuator Failure – Seeking Repair Advice/Shop Recs in NM
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by D Weaver, Jan 20, 2026.
  1. D Weaver
    D Weaver New Member
    Rio Rancho, NM
    Hello everyone,
    I have a 2007 Toyota Prius (Gen 2) with about 171,000 miles that's stuck in permanent limp mode due to what appears to be a failed brake actuator assembly.
    Current symptoms:
    • C1259 and C1310 codes (ABS actuator-related) confirmed with my own OBD-II scan
    • Very poor acceleration – barely drivable, only safe for short local trips on city streets (no freeway)
    • Gasoline engine runs constantly (trying to charge the hybrid system)
    • Consumption screen does not display the hybrid battery at all (system seems to have it offline / no proper regenerative braking)
    • Red triangle warning light and other dash warnings on
    Recent repairs / history (to show it's not a neglected car):
    • Hybrid battery replaced successfully ~3 years ago
    • Instrument cluster replaced summer 2025
    • Inverter coolant pump replaced summer 2025 (DIY)
    • Brakes (pads, rotors, fluid) serviced fall 2025 – fluid level and condition look good
    I've ruled out most other common causes through testing and the symptoms match classic Gen 2 brake actuator failure.
    What I'm looking for:
    1. Shop or mobile mechanic recommendations in the Albuquerque / Rio Rancho, NM area (ZIP 87124) that have experience with Gen 2 Prius brake actuator replacements. Ideally someone who:
      • Uses Techstream (or equivalent) for proper bleeding
      • Is willing to quote labor-only for install + bleed if I supply the part
      • Won’t insist on a full $200+ diagnostic fee since I already have the codes and symptoms
    2. Recent experiences (2025–2026) with part sourcing and costs:
      • New OEM actuator cost? (~$1,300–$1,800)?
      • Aftermarket best options? (i.e. Amazon listings ~$400–$700, or eBay?)
      • Used OEM pulls (risks vs. rewards) ?
      • Any luck finding reman parts? (Dorman 587-765 appears discontinued/out of stock at major chains like O'Reilly)
    3. Realistic total repair costs people have paid lately for this job in the Southwest (labor + part)
    4. Whether it’s worth fixing at this mileage vs. selling as-is (I'm torn)
    I just emailed PriusKings (they claim Albuquerque coverage) and will update here with what they say. In the meantime, any local shop/mechanic suggestions or tips from folks who’ve gone through this would be hugely appreciated!
    Thanks in advance for any help – this has been a challenge.
  2. Brian1954
    Brian1954 Senior Member
    2,493
    999
    South Central PA, USA
    • Codes C1259 and C1310 do not mean the brake actuator is bad. Those two codes just mean that there is a trouble code reported by the hybrid vehicle control ECU. This is confirmed by the red triangle warning light (master warning light). The scanner that you are using is not capable of communicating with the hybrid vehicle control ECU. You need a better scanner to read all the trouble codes that the car is trying to tell you about.
      My guess is a problem with the hybrid battery, but you need a scanner to read the trouble codes from the hybrid vehicle control ECU.
    #2 Brian1954, Jan 22, 2026
