2007 Prius - can't transfer phonebook from my Samsung SIII
Discussion in 'Gen 2 Prius Main Forum' started by Nathan Herber, Oct 16, 2013.
  1. Nathan Herber
    Nathan Herber New Member
    I am following the instruction in the manual for transferring my contacts. It sits at the "waitting to transfer" screen forever...is there a format issue or something else I may be doing wrong?
    My 2012 Passat transferred them in 5 seconds and it was seamless...I can only assume itys a compatability/new/old technology issue...
  2. desmondlee
    desmondlee Member
    204
    27
    2013 Prius v wagon
    when i tried to do this on my 2007 Prius, it would only transfer one contact and that is all - so I gave up
    On my 2013 Prius V it took a minute or so to transfer the whole contact list
  3. Nathan Herber
    Thanks desmondlee....I suspect I am out of luck...
  4. Mohammad
    Mohammad New Member
    actually what you can do is when you got the waiting transfer screen go to your mobile contacts and press on the option then you will see share on the top of the menu then choose Bluetooth then select all contacts then all your contacts will be transferred.
