2007 Prius Problems
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by RedArrow, Jul 11, 2019.
  1. RedArrow
    RedArrow Junior Member
    Knoxville, TN
    I really like my 2007 Prius, but the check engine light came on and with my code scanner I
    received the following 3 problems:
    C1256
    Accumulator low pressure malfunction.
    C1300
    Malfunction in engine control unit.
    P0301
    Cylinder 1 misfire detected.
    Sound like I have serious problems.
    Any information and direction would be appreciated .
    Thanks H. Hampton.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,782
    2017 Prius c
    ANY time you have codes which are seemingly unrelated that show up all together................
    The prudent thing to do is first check the 12 V battery and it's connections.
    48,946
    check the gas cap
  4. JC91006
    16,470
    8,383
    You can check why cylinder 1 is having an issue, only 3 common causes.
    Plugs
    Coil
    Fuel Injector
    Skibob likes this.
  5. RedArrow
    Knoxville, TN
    Thanks for all the replies. I took my Prius to a shop that does Prius repair and their answer was that the anti skid brake unit was at fault.
    They quoted $2500 for the repair. My Blue Reader gave me the same (but more detailed) report of the same fault. I will not pay this
    for the repair. I will drive the Prius as is and see how many more miles I can get from it. Thanks again.
  6. sam spade 2
    7,035
    2,782
    2017 Prius c
    Well you had better drive it REAL carefully because now you probably do NOT have anti-lock brakes anymore.
    If you are lucky they will still function as standard brakes.
    I think you should find a big, empty paved space somewhere and do a HARD stop or two to see how it acts.
    Without ABS, it might throw you into a NASTY spin.
  7. RedArrow
    Knoxville, TN
    Actually, I have been driving without ABS for some time with no problems. But thanks for your help and reply.
    SFO likes this.
  8. Patrick Wong
    18,198
    6,464
    What is the odometer reading?
    Your car has at least 2 problems.
    1. The brake actuator needs to be replaced; consider installing a used unit which you can buy on eBay for ~$300
    2. The engine has a misfire in cylinder 1. As previously stated, this might be due to a spark plug, spark igniter, or fuel injector. This potentially could be a relatively easy issue to resolve.
    James1964 likes this.
