2007 prius replaced drive battery, will not go in drive
Discussion in 'Gen 2 Prius Technical Discussion' started by Greg Grieve, Jun 16, 2016.
  1. Greg Grieve
    Greg Grieve Junior Member
    17
    Pa
    this car had codes, change drive battery, cell 11 and 12 bad, I changed the drive battery (dorman) cleared all codes, dash lights all off. drove 10miles parked and turned it off, one hour later pushed start button. triagle of death on dash and little car in upper left with exclamation point on screen. will not go in drive or reverse . scan for codes, no codes. inverter pump is running, gas engine is not running to charge drive battery, drive battery is 80% charged. can,t find any rason for this condition. car has 223,500mi. this car is clean through out.
    donthack likes this.
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,365
    3,209
    Madison, Wisconsin
    You will need the codes.
    In the meantime, put your high voltage safety gloves on, and go back and make sure the orange plug is firmly seated.
    Also check your 12v battery voltage. (you don't need High voltage safety gloves for that.
    Greg Grieve likes this.
    48,986
    welcome! what are you reading the codes with?
  4. Greg Grieve
    17
    Pa
    I have a new 12v battery coming in the morning, I have removed and reinstalled orange plug many times,will check it againg.
  5. Greg Grieve
    17
    Pa
    I am using a Actron autoscaner did not wright down codes before drive battery change my bad, but it said bad cells 11 and 12 and replace drive battery
  6. bisco
    48,986
    maybe you need mini vci?
  7. Greg Grieve
    17
    Pa
    I am a 35 year mechanic, but never had a prius in my shop,
    what is a mini vci?
  8. bisco
    48,986
    it's the toyota code reader, you can get it on line for cheap and you need an old windows laptop.
    or a dealer can scan it for a hundred bucks or so.
  9. ericbecky
    4,365
    3,209
    Madison, Wisconsin
    As part of changing the battery you must clean the hybrid battery fan.
    Double check that the plug for that is fully seated as well. It will prevent the car from starting otherwise.
    The Action should give you most codes.
    Feel free to call me if you still are stuck.
  10. Greg Grieve
    17
    Pa
    The Hybrid fan had been running all the time with old drive battery, I cleaned it. I will check connection to fan, I have not heard fan run since I changed the drive battery (is it called drive battery or just Hybrid battery?)
  11. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    Drive or HV Battery both terms are equally acknowledged on PC. You need to pull your codes. Others have had DTC issues with remanned Dorman batteries, others have had no issues.
  12. Greg Grieve
    17
    Pa
    so I put a new 12v battery in, checked fan connection at HV battery, still will not go in drive or reverse, no codes.
  13. bisco
    48,986
    did you do the proper snap and slide of the high voltage switch on the hv battery? it is not intuitive.
  14. Greg Grieve
    17
    Pa
    I think I have it in right, push in slide handle down, I looked at it installed and the little button in the slide that shows in the slot of handle is showing. I took the High volt switch out waited then pushed start button on dash looked at screen and it showed 7 bars on the HV battery, is that normal? how do you tell if HV battery is getting connected to inverter ?
  15. bisco
    48,986
    no idea. i'm still thinking codes, but perhaps someone else has a suggestion.
  16. Greg Grieve
    17
    Pa
    just got done with work , now i can put my time in this prius prob. I have no code with my scaner, I will get that mini VCI cable. can the mini VCI and toyota code reader pull more codes that my scaner can? (actron code reader plus). why can't the prius just tell me on the screen why it will not start, just a old man thinking out loud.
  17. bisco
    48,986
    i'm no expert, but everything i've read here, nothing reads all toyota codes except tech stream.
    have you checked all the fuses, including high voltage on battery?
    what does the new 12v read when cold and everything off? are the connections good, including ground to body?
  18. Greg Grieve
    17
    Pa
    checked all fuses, under hood and dash, checked that high volt orange plug and the the little shunt in the handle.
    new 12v battery test 540crank amp. all connections are clean. will get back down to my shop in a minute. and check 12v battery installed and connected to car.
  19. bisco
    48,986
    another potential problem is a bad shifter. i think there are threads here.
  20. Greg Grieve
    17
    Pa
    the shifter will go in nutral and the park button works. I am going to check inverter coolant senser if it has one and the shifter.
