2007 Prius touring, Traction battery diagnosis and repair
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Robert Golden, Apr 8, 2026.
  1. Robert Golden
    Robert Golden New Member
    Tucson AZ
    Three Touring
    Which, if any, of these traction battery cells need replaced?
    April 7, 2026 hybrid battery voltage: 14.48, 14.29, 14.24, 14.05, 14.32, 13.84,
    14.07, 13.49, 13.05, 14.07, 14.10, 14.19,14.26,14.52
  2. JC91006
    16,841
    8,610
    if these are readings from the original 2007 battery, it's best you replace the entire battery with a used "newer" battery. The battery will need replacement modules and reconditioning. And even after that, it may not last very long if it's from 2007 (nearly 19 years old)
    Brian1954 likes this.
  3. pasadena_commut
    pasadena_commut Senior Member
    2,897
    873
    Southern California
    There is a whole long process for reconditioning modules. The voltage at one time point is not the whole story. (Well, unless there is obviously a shorted cell.) For instance, there might be two modules that happen to be at the same voltage right now but have wildly different resistances. The pack will quickly go out of balance in that case. These packs do not like heat, and Tucson is even hotter than it is here. The pack on our 2007 was replaced a couple of years ago. I wasn't going to bother trying to recondition a battery that old, an OEM one was put in instead.
    One caveat, does the OP know that the pack is OEM inside? Toyota might not return the core charge if the innards are different. For instance, there are packs which use cylindrical cells. I don't know if they will take a pack which has the lithium ion modules in it.
