2007 Prius using up a lot of oil
Discussion in 'Gen 2 Prius Main Forum' started by AJP, Mar 19, 2023.
  1. AJP
    AJP Member
    124
    I'm going through a tank of oil roughly every 3,000 miles over a 3-4 month time period. It's at the low dot on the meter (although IMHO the dipstick is a poor design, it always scrapes the oil upward as you pull it out and doesn't give a super accurate reading).
    Past three oil changes:
    5 months / 3700 miles
    4 months / 3000 miles
    3 months / 3000 miles
    My mileage is 170,7000.
  2. Tombukt2
    Tombukt2 Senior Member
    7,790
    1,348
    Durham NC
    Wer you located ? This is common for a worn out 1NZ. Well worn
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,780
    2017 Prius c
    What is a "tank" of oil ?
    And what "meter" are you talking about ?
    Being at the low mark is a quart low.......not empty.
    Given your car's age and mileage, that is to be expected.
    Switching to a "high mileage" oil might help a little but probably not much.
  4. AJP
    AJP Member
    124
    I'm located in PA. What is a 1NZ?
  5. AJP
    AJP Member
    124
    The meter is the dipstick. I was just using the word "tank" for the oil reservoir in the car.
  6. AJP
    AJP Member
    124
    Do I need a full oil change, or just top it off with oil until I hit the 5-6 month mark?
  7. pasadena_commut
    pasadena_commut Senior Member
    1,329
    404
    Southern California
    Add a quart of oil when it gets to the low dot, no need to change the oil just because it is low.
    If you read the dipstick when the car is cold and has sat overnight most of the oil should have drained back, so the initial reading is cleaner. I agree that if the stick is read "conventionally", which is pull it out, wipe it off, put it back, pull it out, read, there is often oil smeared up the side of the dipstick.
  8. sam spade 2
    7,035
    2,780
    2017 Prius c
    THIS.
