1. The site is migrating to a new server this week, so there will likely be some downtime during that process. You can follow along here for updates.
2007 Prius w/150k miles, original battery - Hybrid synergy drive constantly running. Ideas why?
Discussion in 'Gen 2 Prius Main Forum' started by Warren CA, May 2, 2021.
  1. Warren CA
    Warren CA New Member
    My 2007 Prius w/150k miles and original battery has a problem with the Hybrid Synergy Drive constantly running every 10 seconds when driving and at park. Also has a thumping sound. Any ideas why this is happening? Suggestions on fixing?
  2. TMR-JWAP
    TMR-JWAP Senior Member
    5,832
    5,614
    Columbia, SC
    That's the brake actuator/accumulator running. Apparently you have a problem with pressure bleeding off. Pretty common problem.
    search Prius brake actuator and you'll get hundreds of hits.
    Sometimes it can be resolved by a brake fluid flush. Sometimes it's only a short term solution. If it gets to the point of getting the red triangle, it normally requires replacement of the actuator.
Loading...
