2007 Prius with new hybrid battery showing red triangle
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Thomas Althoff, Apr 13, 2016.
  1. Thomas Althoff
    Thomas Althoff New Member
    Vinton VA
    I have a 2007 Prius with 107k miles. Last July it had a minor drivers side front end collision. Last November it had the hybrid battery replaced. I believe all this is unrelated just putting it out there for information.
    I am currently having the red triangle pop up intermittently. When it does a "problem" message will display on the MFD. This seems to occur most often after a long downhill or when the Energy display is showing the hybrid battery is nearly full.
    The hybrid battery seems to be functioning normal and the car is driving normal and has expected fuel economy. I do have a headlight that cuts out occasionally but no other noticeable electrical problems. I do not have a diagnostic device to get the codes.
  2. S Keith
    S Keith Senior Member
    799
    327
    AZ
    2003 Prius
    Read the codes. Options in my signature.
    48,946
    is it a new toyota battery replaced under warranty?
  4. JC91006
    16,470
    8,383
    How's the engine oil level?
  5. ericbecky
    ericbecky Hybrid Battery Hero
    4,365
    3,209
    Madison, Wisconsin
    Yep. You'll need the codes to help point you in the right direction.
    Otherwise it's just wild guessing.
  6. Thomas Althoff
    Vinton VA
    New hybrid battery was replaced at the local Toyota dealership.
  7. S Keith
    799
    327
    AZ
    2003 Prius
    Statistically speaking, it is highly unlikely to be your battery.
    Again, code reading options in my signature. MiniVCI is the best option.
