2008 Prius - burning oil at 135,000 miles
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Dave333, Dec 10, 2012.
  1. Dave333
    Dave333 New Member
    My dealer is telling me that my gas engine may need to be replaced because it is burning oil. I drive nearly 200 miles a day and mostly on the highway, i.e., 75 mph. I have stopped in for an oil log at about 1,000 mile intervals. At the first check, the oil was still full. Second check, about a quarter of a quart of oil was burned, third, 7/8ths of a quart.
    What should I do? The dealer says change the oil every 3K miles. Or replace the engine? Or sell it?
    If I am changing the oil every 3K, is it ok to go to Jiffy Lube and use their high mileage oil? Or is there some better engine oil that I should use?
    Thanks for any insight -
    Daves09prius likes this.
  2. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    I would use Toyota full synthetic and change every 10 to 12 thousand miles. I t runs about $6.75 a liter here in Canada and it is probably cheaper in the US. It may use less oil with synthetic? Make sure they don't over fill. Good luck, H
    48,984
    welcome to p/c! i would just keep adding oil. why bother changing it if your're continually adding fresh? maybe change the filter every 5000. i don't see why you would need a new engine unless it won't pass emissions, and then, would it be cheaper to replace valve seals or whatever is causing it?
    PriusGuy32 likes this.
  4. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    775
    360
    This is becoming a common problem. As far as I know, no one has figured out a simple solution. I have been trying different things to see if there is a way to help aside from engine replacement. I only use synthetic motor oil and can assure you it will not fix this problem, at least in a short time. So far I have replaced a PCV valve, put in Sea foam and Rislone (all in different Prii). Marvel mystery oil is next. My Prius does not consume any oil, therefore, I am experimenting with customers Prii and have not had any return yet (don't worry, they will) to monitor the outcomes. In case anyone is wondering these customers are fully aware of the experimentation. I look forward to other members sharing there experiences with this problem.
    Wonder, johnjohnchu, JMD and 3 others like this.
  5. uart
    uart Senior Member
    4,215
    1,200
    Australia
    High speed driving can increase oil consumption in some cases. Apparent oil consumption can vary from week to week due factors like temperature, speed, length of journeys and fuel dilution. So you should rightly just average your three fuel logs, which works out about 0.38 qts per 1000 miles - or one quart per 2700 miles.
    This is pretty high, but not so terrible to necessarily need a new engine right now. The most important thing is to keep the oil up to it, check it regularly and don't let it get too close to the low level on the dipstick. If you let it get too low then things are gonna go from bad to worse really quickly.
    If you give your location (or say what sort of temperatures you're operating in) then it would make it easier to give oil recommendations. I recommend that you try Valvoline Maxlife 5W30 conventional at with about 5000 to 6000 mile intervals.
  6. Joe 26
    Joe 26 Member
    242
    42
    Columbus, Ohio
    Have you taken apart any of these engines or heard from a dealer who has determined the cause? There was a campaign a while back on the Corolla engines where you would find polished sections of cylinder wall (no crosshatch) and excessive oil consumption.
  7. northwichita
    481
    102
    29
    Wichita KS
    Another thread has 600 miles / quart as a guide for the dealership changing the engine, at least for warranty work-----
    Low oil - Red Triangle w/ Exclamation Point | PriusChat
    Also some suggestions for oil consumption in above thread.
  8. CBarr31
    CBarr31 Active Member
    434
    225
    Charlotte, NC
    Dave,
    Your mileage does seem a little low for burning oil but isn't out of the realm of possibility. If you have been using dino oil I would just keep using that but switch to a high mileage brand. If you have been using synthetic I would switch to a synthetic high mileage brand.
    My car, Ema, is burning about a quart or so every 2,000 - 2,500 miles. I don't believe this is becoming a "common" problem as Avi said I just think there are starting to be a lot more high mileage Prii out there. High mileage vehicles will burn oil plain and simple. Esecially those that have a lot of highway miles like Ema. I tried Restore and it didn't do any good with the burn. I may go to a heavier oil in the summer and take the hit to my MPG's but haven't decided yet.
    My recommendations as others have posted is to monitor it and add oil as needed. Change the oil and filter every 5,000 miles even with the putting in fresh because most high mileage oils will do some cleaning as well. Whether you want to try a cleaner or not is up to you. I highly doubt any of them will "hurt" but as one other poster said somewhere "There isn't anything you can pour into an engine to stop it from burning oil." So far I have found that to be true. I hope this little bit of info helps.
    Happy driving,
    Chris
  9. Dave333
    Dave333 New Member
    I am in Vermont, USA. During the summer months, I commute over a steep mountain pass that is very curvy. The way up puts a lot of strain on the gas engine, while the way down is great for recharging the battery (I use the B setting to take advantage of engine braking). During the winter, I am driving on aggressive snow tires in low temps and mostly on less than a 6% slope.
    I am hesitant to go more than 3K because that is what the dealer recommended, but at the same time, I don't want to spend so much money on getting the oil changed if it's not going to pay off in longer engine life.
  10. Joe 26
    Joe 26 Member
    242
    42
    Columbus, Ohio
    With today's engines and oils, especially on a Prius, there is little justification for a 3k oil change interval. It is designed to get you into their service bay more frequently, nothing more. The stealer makes his living off convincing people to over-maintain ther vehicles; that's one reason I am no longer in that business. I use synthetic and go 8k between changes. Since you are using some oil, you may want to stick with dino, but extend the interval to at least 4k, if not 5.
  11. roamerr
    roamerr Member
    135
    43
    Winston-Salem, NC
    Let's see. You are 7/8 of a quart down after 3k miles. I assume this is using 0w-20. I'd switch to 5 w 30 and see what happens -- that might get you to a quart every 5k miles. A quart every 3k miles is not bad at all. I'd just add the oil and not worry. If it bothers you just get your oil changed every 3k with the cheapest oil change and let'r roll.
    Oil is cheap. Engines are not. If you get to a quart every 1k miles then I'd start to worry. Doubt you will ever see that happen.
  12. Dave333
    Dave333 New Member
    I'm down more than 7/8ths after 3k. The first log check after an oil change was at about 1,200 and there was no loss, the second log check was after another 1,300 miles and I had lost a 1/4 of a quart, they topped it off and after the third log in at another 1.300 miles, I had lost another 7/8ths of quart. Does this change your opinion?
  13. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    As mentioned, keep an eye on it and add oil as needed. Yuor oil consumptiom is not bad as all.
    DBCassidy
  14. Avi's Advanced Automotive
    775
    360
    I have not had the opportunity to take one apart. Maybe a look into the cylinder of one of these engines would reveal something?
    FYI I have six GenII customers with this problem and zero GenI customers with it, some of them with over 200K on the clock. You are entitled to believe whatever you want, this is what I am seeing.
    Avi
  15. Joe 26
    Joe 26 Member
    242
    42
    Columbus, Ohio
    It would be difficult to see with a boroscope, maybe if you replace one of these you can crack it open.
  16. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Thanks for the clarification Dave. That was the way I first read it, but it wasn't totally clear. So basically 9/8ths of a quart over 3,900 miles. Yeah it's not ideal, but not all that bad either. It's still easily manageable at this stage, heck my brother's got an Audi that's been using that much since it was new. You just have to keep the oil up to it, top off every week with the amount of miles you drive. Don't let it get down to the bottom quarter range on the dipstick.
    BTW. What oil (brand/grade) are you currently using? You may still be able control it a bit with oil choice.
  17. PriusGuy32
    1,411
    506
    Harrison Township, Michigan
    I wouldnt replace the whole ICE just because its burning oil. Heck, a quart of dino oil at Wal-mart is $2.49. It would take A LOT of quarts to equal out the cost of a new ICE. And you are burning about a quart every 4000 miles. The oil change interval is 5000 miles. I'd just top off the oil level at that point and extend my OCI to 6500 miles.
    Of course, the ICE can be re-ringed and a valve job performed if need be. A new engine doesnt need to be dropped in. The rebuild will be pretty cheap compared to a new ICE....
    JMD likes this.
  18. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Yep, and if he buys his oil in 5 qt jugs then there will be enough left over to keep it topped off for a 5k to 6k OCI anyway. The extra costs would be absolutely minimal.
  19. PriusGuy32
    1,411
    506
    Not to mention, if you check out the rebates and discounts section over at bob is the oil guy, you can get 5 quart jugs for FREE after rebate all of the time. I have 3-4 five quart jugs of Mobil 5000 that were free after rebate. Dont use them for anything but top-off oil in the lawnmowers and boats but it was free, so who cares :D
    If the OP could get oil that way, then they'd be even more ahead of the game. Top off oil for Prius that burns a quart every 4000 miles for free? Winning. :cool:
  20. CBarr31
    434
    225
    Charlotte, NC
    Avi,
    Any update on the Marvel mystery oil test or any other "treatment" that helps with the BURN? As I mentioned previously Restore doesn't seem to help, at least in my specific case.
    Ema is at about 333K and still burning about 1 qt. every 2,000 miles or maybe a little more. I've found that when you add a full quart or more the burn seems to be a little less rather than just topping off with a 1/4 quart or so more often. It also seems to burn a little less after an oil change. Which seems to indicate the problem is exacerbated by sludge and carbon buildup in the engine and that it is partially cleaned when you replace your oil and filter. So the idea of going back to a 3,000 mile or 3,500 mile oil change especially if you change your oil yourself probably isn't a bad suggestion as some have been told to do.
    Look forward to hear how your extensive testing has gone.
    Chris
