Bay Area: 2008 Prius engine won't turn, Main Battery Error
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SantaRosaPrius, Jun 22, 2022.
  1. SantaRosaPrius
    SantaRosaPrius New Member
    Santa Rosa
    Hello all, and thanks in advance for any help that ensues.
    I have a 2008 Prius with an engine that won't turn. I just replace the 12V battery. When I turn the car on I get the red triangle of fun, and a main battery error message. It will not allow me to put the car into anything other than P and N. States that it cannot charge the battery in N, if I try to take it out of park. The car hasn't been driven in well over a year.
    My assumption is that the traction battery is completely discharged. Is there anyway to jump or push start the car? I live in the Bay Area, is there any place where I can rent a grid charger or have someone come out and charge it? Is there any other means of charging it? Am I not seeing an option besides replacing the traction battery or getting it charged at the dealership?
    Thanks in advance
    Also if this has been answered in another post please direct me to it.
  2. JC91006
    16,470
    8,383
    Are you certain the 12v battery you put on is good? The hybrid battery shouldn't discharge to the point it won't start (unless it's really weak).
    I would check the 12v health and then check all the fuses in the car, make sure nothing else can be contributing to the no start
    48,999
    there are a bunch of people in your area who can help. change your title
  4. SFO
    SFO Senior Member
    5,286
    4,226
    Northern California
    Welcome to PriusChat!!
    Confirm with a voltmeter that you have 12v at the battery, and again at the jumper points under the front hood.
    Are all of the 12v connections good, including the negative strap that starts from the battery and attaches to the body? (known rust spot)
    Generally speaking, if there are warning lights being displayed on the dash, there are OBD2 codes (DTCs) stored in the computers (ECUs). Locate a toyota hybrid compatible scanner and retrieve the codes, then post them here for additional guidance.
    There is a Prolong grid setup including a gen2 harness in SF (delivery may be possible), and you can build a DIY grid charger as well.
    FYI : you're moderated until you've posted 5 times.
  5. SantaRosaPrius
    Santa Rosa
    Whom might I contact to get a hold of the Prolong grid setup with charger?
    Also, thank you very much for your help
    SFO likes this.
  6. SFO
    SFO Senior Member
    5,286
    4,226
    Northern California
    Send me a PM (start a conversation), or include a contact in your profile.
    #6 SFO, Jul 9, 2022
