2008 Prius splash shield hanging down. Should I just remove it and throw it in the trash?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Josh Lyman, Oct 17, 2017.
  1. Josh Lyman
    Josh Lyman Junior Member
    36
    Washington, D.C.
    I bought this car in January and the previous (only) owner said he already replaced it once. There was no parking stop incident I recall, but I do slightly bottom out when coming in/out of my driveway. From what I've read, it's a common problem that will keep happening. Does the splash shield actually do anything useful, or should I just remove it and throw it in the trash?
    prius_nerd likes this.
  2. Jmack111
    Jmack111 Member
    370
    78
    Tacoma wa
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,795
    Clearwater, Florida
    Its there for an important reason.
    That front cover is very important its the FOD cover to protect the AC Condenser from road debris. Get under there and look up at the front of the radiator above that busted cover.
    Thats the AC Condenser your looking at. One nice rock through it and no ac and your looking at a very big $$$$$ bill.
    Not only that all the road dirt will get sucked in there and clog the condenser up real quick. Most people never clean them.
    That usually damages the ac compressor. Clean condenser keeps the compressor cool and you get very cold ac. I clean mine regularly. Just like my home ac.Basic maintenance.
    Btw, I have been through this also and found the under cover panels you buy on ebay are a Chinese joke. There like a piece of flimsy cheap plastic rolled up. Total junk don't waste your money.
    Go online to like Olathe Toyota and buy the original under cover panel. There not expensive.
    dolj and bisco like this.
  4. edthefox5
    10,096
    4,795
    Clearwater, Florida
    Like your name.
    Btw, my wife is a WW fanatic. I have seen every episode about a thousand times really well done show. Sad to compare what we have now.
  5. Josh Lyman
    36
    Washington, D.C.
    Sounds like I should just get the part from a junkyard whenever a compatible Prius shows up in their inventory, but that it's not a super urgent issue until then. At least, not with the city driving and lack of snow here in Atlanta.
  6. Mendel Leisk
    38,101
  7. bisco
    48,861
    just drill some holes and wire it all up with galvi wire.
  8. exstudent
    exstudent Senior Member
    2,207
    897
    Torrance, CA
    You likely only need a plastic fastner. I bet this fastner gets inserted into a common hole that spans the falling plastic piece and the neighboring plastic piece.
    Call/contact Autobeyours, Prius hybrids sales and service Scottsburg Indiana They will likely have the plastic fastner that you need. They will definetly have the hanging plastic piece you are considering to replace.
    If you have tools jack stand and floor jack. Take a picture of the underside to see what fastners are missing. This will help autobeyours know exactly which ones are missing.
  9. prius_nerd
    prius_nerd Junior Member
    29
    Georgia, USA
    We fixed ours within a couple minutes just now using only some zipties, which are super cheap and easy to use:
    donbright likes this.
