2009 ABS Pump part number 44510-47050 v. 44510-47051. Interchangeable?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Kyle G, Jul 21, 2021.
Tags:
  1. Kyle G
    Kyle G New Member
    Tampa
    Are 2009 Prius ABS pump part numbers 44510-47050 and 44510-47051 Interchangeable? I pulled mine today and the part number is -47051 and not the -47050 I see listed everywhere. They look exactly the same.
  2. Too Many Prii
    Too Many Prii Junior Member
    The Lone Star State
    Did you ever learn more?
  3. Kyle G
    Kyle G New Member
    Tampa
    yes, they are interchangeable. I installed and it worked great.
  4. dolj
    dolj Senior Member
    7,483
    3,763
    Wellington, New Zealand
    The -47051 is the updated part so would be better to try for that if you can, but as you say the -47050 part is more plentiful.
    @Too Many Prii, for your 2008 model apparently the part number is as below"
    Toyota 44500-47140 –– ACTUATOR Assembly, Brake
    2005-2009 Toyota Prius
    Part Description
    Part Name Code –– 44510
    Replaced By –– 44500-47141
    Manufacturer –– Toyota
    #4 dolj, Aug 17, 2021
    Kasra likes this.
