200A lifepo and 2kw 220V inverter hooked to traction battery?
Discussion in 'Prius PHEV Plug-In Modifications' started by teranaught, May 16, 2024.
  1. teranaught
    teranaught New Member
    bremerton
    4 of these units could add 8 kw demand and 10kwh to EV only use, I have little experience with Prius batteries.
    opinions?
    Voltage controlled to maintain %80 charge you could add as many as you could fit.
    Basically a dc to dc converter add a bridge diode to the ac and let them run.
    When soc gets low the inverter turns on.
    I am a retired electronic tech, I've got 4 weeks with a 2006 Prius.
    I will drive this for a few years then upgrade, that should give me time to learn what to upgrade to.
    49,492
    sounds like a lot of missionary work. it can and has been done, but only by the best and brightest.
    all the best, please keep us posted!
