2010- Multiple EGR Power Wash Cleaning, No Chemicals/Soap
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Prius_Angie, Jul 9, 2020.
  1. Prius_Angie
    Prius_Angie Active Member
    245
    228
    Saint Louis
    I recently went to the self-serve car wash to clean out 2x EGR coolers and 4x EGR valves. WOW that was a fun, fast, productive and rewarding cleaning all conducted with no harmful chemicals nor soap but only high pressure water alone. I estimate a 90% clean product as some radiator holes were still visually obstructed. I shall revisit this process in ~5 years/100,000 miles, possibly.
    GOAL
    - water freely flowing bidirectionally through EGR cooler and no more brackish water coming out the other end
    PREP EGR-VALVES
    - I separate 2x EGR valve from their 2x EGR cooler
    - I drilled 2x holes into a 2x6 wood block to stabilize the 4x EGR valves for cap extractions
    - I used a high quality CAPRI 1/2" drive impact screwdriver set; a must
    PREP EGR-COOLERS
    - separately with wood screws, I anchored 2x EGR coolers to a block of 2x6 wood; this was sufficient to stabilize both EGR coolers when under the high water pressure; I ensured water nozzle access to both sides of each EGR cooler
    POWER WASHING
    - I gently placed my foot on a wood block to secure positioning of the 2x EGR coolers to clean
    - when entering the water gun nozzle into both ends of EGR coolers I move in 360 degree angles while inside; you will quickly find all kinds of black gunk ejecting; add a few more quarters and keep the 360 rotation going for another 1-2 mins until you find water freely blowing through and no more brackish water coming out the other cooler end
    - run this cycle at least 1-2 more times to ensure thorough cleaning
    - 4x EGR-valves were also power washed without any special clamp downs
    1.jpg 2.jpg 5.jpg 8.jpg 6.jpg 7.jpg 3.jpg 4.jpg 10.jpg 11.jpg 12.jpg 13.jpg 14.jpg 20.jpg 18.jpg 19.jpg 15.jpg 16.jpg 17.jpg 21.jpg 22.jpg 24.jpg 25.jpg 26.jpg 27.jpg 28.jpg 29.jpg 30.jpg 31.jpg 32.jpg 33.jpg 34.jpg 35.jpg 36.jpg 37.jpg
      File size:
      95 KB
    #1 Prius_Angie, Jul 9, 2020
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,476
    Bay Area, California
    2019 Prius Prime
    Pressure washer is the way to go:).
    Glad it was successful(y).
    James Analytic and Prius_Angie like this.
  3. Prius_Angie
    245
    228
    Saint Louis
    thanks to you guys for the tipper
    Raytheeagle likes this.
  4. Raytheeagle
    11,251
    15,476
    2019 Prius Prime
    Glad to help:).
    It is the way to go to make the job easy and fast(y).
    Prius_Angie likes this.
  5. Prius_Angie
    245
    228
    Saint Louis
    How do you like your new 4thGen? Is your 4thGen free of the EGR issues? I would only assume Toyota promoted up with the 4thGen.
  6. ASRDogman
    ASRDogman Senior Member
    5,887
    3,159
    Don't you mean bLackish water? Brackish water is where fresh and salt water mix I believe.
    Anyway, if you used oven cleaner afterward, you'll find that it will be black when you pressure it again.
    When I cleaned mine, it looked clean and shiny after pressure washing. I was happy. But I used the
    oven cleaner just to see. I had to use it 3 times I think it was before the water was clear.
    The pressure cleaning alone will clear it, but not completely clean it. Unless you have some type of
    cleaner mixing with it.
    And all that "gunk from the pressure washing goes down the drain.
    Nice photos! And pressure washing certainly the easiest and quickest way to clear it out!
  7. Raytheeagle
    11,251
    15,476
    2019 Prius Prime
    I am glad I upgraded ;).
    It's not to say the gen3 was bad, just having the ability to get 140 mpg over 23k miles with free electrons at work and with solar panels made this a pretty easy move:).
    As for the egr situation, too early to tell:cool:.
    But once I get over 100k miles, I'll take a look. Already have an oil catch can installed, so I should be prepped for a good bit(y).
  8. Raytheeagle
    11,251
    15,476
    2019 Prius Prime
    My goal was not to be so clean you could eat out of it:whistle:.
    It'll just get dirty again, so why do more if you know you'll have to repeat the cycle again;).
    15 minutes with 1700 psi and you can reinstall and get the rest of the egr circuit sorted:).
    But each person has a different level of OCD, so I can appreciate the cleanliness factor(y).
    Grit, mjoo and Prius_Angie like this.
  9. Prius_Angie
    245
    228
    Saint Louis
    sorry TYPO "blackish water" definitely not salty-fresh water mixture.
    It was definitely a hot day & me being at the carwash was a treat that directed my focus
    seems that 90% complete seemed good enough
    next time i will bring along some oven cleaner spray
    thanks.
    ASRDogman and Raytheeagle like this.
  10. mjoo
    mjoo Senior Member
    1,107
    1,311
    Michigan
    LOL. With all the work needed to remove the EGR from your Gen 4 (inverter removal) - if that time comes I bet you'll find a new level of OCD.
    #10 mjoo, Jul 10, 2020
  11. Mendel Leisk
    38,201
    Did you pressure wash EGR valve too?
  12. ASRDogman
    5,887
    3,159
    :) That's what i figured.
    ocd has nothing to do with it, If you are going to clean it, you might as well do it completely and correctly. :)
    Then it will stay cleaner longer...
    Grit likes this.
  13. Prius_Angie
    245
    228
    Saint Louis
    yes,
    INTERNALLY. I opened up & carburetor spray cleaned all 4x EGR-valves. Also i reset the magnet spinner to full kinetic potential
    EXTERNALLY. I pressure sprayed all the visible carbon on the 4x valve blocks. No chemicals here only water pressure
    #13 Prius_Angie, Jul 10, 2020
  14. Raytheeagle
    11,251
    15,476
    2019 Prius Prime
    I'm only running the ICE 30% of the time anymore:).
    So even less miles in the engine equation;).
    At that rate, I'll only have to perform the act once, and given Toyota changed the takeoff point for the gases to be after the cat, I might be good regardless(y).
    Grit, Prius_Angie and mjoo like this.
  15. Prius_Angie
    245
    228
    Saint Louis
    that plug-in option seems pretty good in defraying gas mileage and ICE-engine wear.
    but Im sure not for everybody.
    I dont have a garage but I do drive 5-75 miles/day
  16. Raytheeagle
    11,251
    15,476
    2019 Prius Prime
    My round trip (when I am essential) is 78 miles;).
    So on average I have to use the ICE about 7 miles a day:).
    The rest of the ICE usage is for trips, which there haven't been as many recently:cool:.
    But once we can, that percentage may drop a bit but still good(y).
    Grit and Prius_Angie like this.
  17. SB6
    SB6 Member
    314
    69
    Just curious, what does this mean?
  18. mjoo
    mjoo Senior Member
    1,107
    1,311
    Michigan
    It sounds like he remodulated the EGR coils to compensate for the temporal flux distortions.
    Prius_Angie, Raytheeagle and SB6 like this.
  19. Prius_Angie
    245
    228
    Saint Louis
    see 1 min marker.
    when you open up the black cap, its evident you will notice the magnetic canister self spins outward and around the spring
    probably a bad analogy is a "jack in the box"
    to close the EGR valve basically spin magnetic canister down and cap lock shut. If left alone, it wants to spin up and out.
    James Analytic likes this.
