2010 Prius 92g/km and low emissions 89g/km version!
Discussion in 'Gen 3 Prius Main Forum' started by drees, Oct 3, 2008.
  1. drees
    drees Senior Member
    1,782
    247
    Found this article on AutoblogGreen talking about the rumored dedicated Lexus hybrid, but it also leaked some interesting tidbits about the fuel economy of the 2010 Prius:
    Full Article here: Confirmed: Lexus to build Prius-based hybrid - AutoblogGreen
    Since those are European measurements, the current Prius emits 104 g/km of CO2, meaning that the next Prius should be about 15% more efficient than the current model.
    This would put the EPA combined fuel economy rating in the 53-54mpg range compared to the 46mpg the Prius is rated at now. Let's hope they are right!
    I wonder if the "low emissions" model will be the one that comes with solar panels?
  2. catgic
    catgic Mastr & Commandr Hybrid Guru
    586
    140
    HTTP 404 Not Found
    HTTP 404 Not Found
  3. KMO
    KMO Senior Member
    1,416
    345
    Finland
    2023 Prius Prime
    Where's the optimistic stretch? g/km and mpg are almost exactly inversely correlated - the figures are produced by the same combined test cycle.
    So if those CO2 figures were correct, it would be 11-14% more efficient on the European test cycle.
    Is there any reason to suppose the EPA test cycle would show a smaller improvement?
  4. miscrms
    miscrms Plug Envious Member
    2,076
    523
    Phoenix, AZ
    I'd say it is a very reasonable calculation. CO2 emission is directly proportional to fuel burned, as it is a direct result of the carbon content of the fuel. The EPA uses a factor of 8788g/gallon for gasoline, or 10084g/gallon for diesel. The only thing you have to be careful of is making sure you are flipped around the right way. 89g/km would be a 14.4% reduction in CO2 output. That would equate to a 14.4% reduction in fuel consumed. 92g/km would be a 11.5% reduction.
    46mpg combined = 2.17g/100mi - 14.4% = 1.86g/100 mi -> 53.8mpg combined
    46mpg combined = 2.17g/100mi - 11.5% = 1.92g/100 mi -> 52.1mpg combined
    drees, good find! Toyota has been saying 10-15% improvement for the '10, but I think this is the first indication we've seen that it may be true.
    catgic, do you have any info/data to back up your guestimate?
    Rob
  5. miscrms
    2,076
    523
    Phoenix, AZ
    RE Solar, I agree mostly. The roof of the Prius has been estimated to hold a little over 200W of PV. Depending where you are in the country, that will generate between 750 and 900Wh per day. Thats enough to drive the Prius about 2-3.5 miles on EV. By comparison the current capacity of the Prius battery from full bars to no bars is ~500-600Wh. If the new Prius battery has enough capacity to store this energy, and an algorithm to make sure it can usually have room for it, then it will make some difference. For a typical 41 mile a day kind of driver, 3 miles EV would reduce fuel consumption by 7%, so the additional 4% above certainly seems feasible. At the current EPA estimated annual fuel cost of $1211, 7% would be $85/year. If the solar option costs more than ~$850 it won't break even. Thats probably in the ballpark, as the retail cost of solar panels is in the $4-6/watt range. On the other hand many people would probably pay a little more to reduce their CO2 output or oil consumption even if it didn't break even in a purely financial argument.
    Rob
  6. drees
    drees Senior Member
    1,782
    247
    For me, the primary benefit of any solar panels on the next Prius will be jumping into a much cooler car on hot days. That alone is with the $1000 bucks to me. Since it will also reduce air conditioning load, especially for the first 5-10 minutes it takes to cool down a car in the summer, it seems that it's a no brainer that it will also help fuel economy a bit, but again, from my point of view, that's all gravy.
    catnic - to put it a bit less gently than Rob - you are pulling your numbers out of your rear. There is no reason to believe that the newer Prius will do any worse than the current one on the highway, even though it has a bigger engine. Don't forget that the current engine in the Prius is 5 years old now and has not been changed in that time. Toyota has a lot of time to improve efficiency. These leaked g/km numbers nearly prove it.
    Heck, if Toyota ever gets around to using direct injection, that alone would bump up fuel economy another 5-10%.
  7. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,994
    Fort Lee, NJ
    Toyota have been working on cutting the cost of hybrid parts for the next gen like the Honda. What if Toyota price the next gen Prius the same as the Insight II? The MSRP for the Insight I and the Classic Prius were the same $19,995. So... why not? This is where the similarity ends...
    It is contrasting to see how IMA is stuck at 1.3L and remain at the same fuel efficiency performance level. In the meantime, HSD is becoming more powerful, more efficient, cleaner and cheaper. If the next gen Prius were to grow in size, 0-60 in 9 seconds, get 15% better MPG, and cost less.... this will make the Insight II just a repackage of IMA to cash in on a quick buck of the Prius supply shortage.
  8. miscrms
    2,076
    523
    Phoenix, AZ
    I think thats the $24,000 question. The Insight could be a winning strategy if the price differentiation is significant. Otherwise its HCH vs. Prius all over again. Smaller, slower, and slightly less efficient for a little less money has not been a winner for the HCH.
  9. Tideland Prius
    16,072
    Yeah but judging from the other thread, catgic doesn't believe that a bigger engine will be more fuel efficent than a 10 year old smaller displacement engine. 10 years is a long time for technology to improve.
    Good point. In Canada, the Insight sold for $26,000 and the Prius sold for $29,990. (That's right, 1.5x more than you guys for the Prius.. but then again, it was 50¢ to the CAD)
  10. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    there is no way Prius will cost as little as Insight - it is bigger everything... If they ever create Yaris version of Prius, it might end up similar in pricing...
    Considering that Toyota built up battery plants to build 1,000,000 hybrids in 2010 alone, i am pretty sure that more hybrid models are coming... Prius is going to take up only half of that, and currently Prius is >80% of their 500,000 per year output... that means 100,000 "other" hybrids are produced right now per year. In 2010, that number for "other" hybrids will go up to 500,000 per year, which means significant new model introductions, not just new and expensive RXh.
    No wonder there are roumors of additional, larger, dedicated Toyota Hybrid and 2 dedicated Lexus hybrids, as well as iQ, etc, etc... Come 2010, Toyota will have a LOT of hybrids to sell.
  11. catgic
    586
    140
    HTTP 404 Not Found
    HTTP 404 Not Found
  12. ken1784
    ken1784 SuperMID designer
    2,940
    1,359
    67
    Yokohama, JAPAN
  13. HomeandRanch
    HomeandRanch New Member
    78
    Hmm if they are pumping that many hybrids out we better unload our Gen 2s before then. If supply goes up that much price will have to come down. Unless we are at $6 gas.
  14. onlynark
    onlynark Member
    189
    bay area
    catgic: You wrote the following:
    Corolla 1.8L I4 AT, curb weight 2595 lbs: EPA 35 MPG “Highway.”
    Yaris 1.5L I4 AT, curb weight 2335 lbs: EPA 35 MPG “Highway.”
    So what you are saying above is that a lighter car with a smaller displacement engine gets the same mileage as a heavier car with a more powerful engine. That means the more powerful engine is more efficient. If you reduce the corolla weight by 260 lbs to make it equal to the weight of the yaris (all else being equal), the hwy mileage should increase by roughly the same amount to ~38 mpg.
  15. usbseawolf2000
    14,487
    2,994
    Fort Lee, NJ
    Source
  16. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    Further to your point the new family of engines going into all Toyota's is the 'R' family. Across the board, in every vehicle, they are far more powerful and noticably more fuel efficient at the same time.
    The 4.0L 1GR and the 3.5L 2GR engines are class leading.
    The 5.7L 3UR is simply the best V8 in the segment.
    The new 1.8L 2ZR in the Corolla is far better than any other such engine in the class.
    The 2AR 2.5L engine is just now going into the RAV and soon into the Camry.
    The 1AR 2.7L will be in the Venza and the Highlander at the end of the year.
    Expect the new Prius to be both more powerful and more fuel efficient. The 10-15% increase is very very realistic. I'd bet on it rather than against it.
  17. Tideland Prius
    16,072
    Yeah but catgic doesn't believe in that.
    Interesting... so they're balancing FE and performance. I know there are a few diehards here that would want nothing more than max FE but I'm sure Toyota's balance would be just right. I wouldn't mind a little more umph to be honest but at the same time, if Toyota keeps the same PSD, we can P&G and get max FE that way too.
    I'm curious about the "low emission" model. Is there a Prius and a Prius GT or something?
  18. Flying White Dutchman
    4,374
    313
    the new prius will have a normal and extra low c02 version
    info straight from paris auto show
    one 92 gr per km
    and one 89 gram per Km
    on this model the new lexus prius wil be based on the market 2010
  19. Tideland Prius
    16,072
    Yeah I know but why two versions? Why not just the extra low? And what is it that's special that makes it extra low?
  20. Andrew Stephenson
    Andrew Stephenson New Member
    UK
    If they can get emissions down below 100gm/Km, that'll mean no (ie, zero, none, null, nada, zilch, zip &c) UK Road Fund to pay. Yay.
    Of course, the saving will only be GBP15/year over what *.gov.uk charges now for 104gm/Km -- but the bragging and snook-cocking rights around soot-belching SUVs may well prove priceless. :D
