2010 Prius - Check Hybrid System after Orange Safety tab removal
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by moon_tanner, Mar 26, 2020.
  1. moon_tanner
    moon_tanner Junior Member
    NW Florida
    Hello,
    I replaced the Brake ABS and Brake Acctuator.
    I disconnected the 12v batter and the orange safety plug to the hybrid batter before removing and installing the brake parts.
    The orange plug is back in, and the 12v battery is almost new.
    When in 'Ready' mode, the car won't go into drive. Only Park and Neutral.
    How can I do more troubleshooting in TechStream?
    Related Articles for others:
    2010 Prius ‘check hybrid system’ | PriusChat
    2010 Prius Check Hybrid System | PriusChat
    2010 prius Check Hybrid system and P lock malfunction | PriusChat
    #1 moon_tanner, Mar 26, 2020
  2. pjksr02
    pjksr02 Active Member
    532
    225
    Connecticut
    What codes does Techstream show? (run Health Check for all systems)
    48,930
    many forget the third step of the safety plug, 'slide'
    Grit likes this.
  4. RRxing
    RRxing Senior Member
    2,518
    1,790
    NEPA
    I don't think it would go into "Ready" mode if the safety plug wasn't installed correctly.
    tankyuong likes this.
  5. moon_tanner
    NW Florida
  6. moon_tanner
    NW Florida
    Thank you all for the help!
    2 new findings:
    1 - I didn't have the orange 'slide' pushed in. I slid the orange lock back in place.
    2 - Error code U0129 Lost connection with brake system control module.
    I bough the 'new' part from a junk yard, so it's very possible that the new brake booster has a bad brake control module. I plan on swapping the bad part back in the car and testing to see if the error goes away. If it does, I'll have to order yet another brake booster.
    I'll update y'all when it's done!
  7. bisco
    48,930
    pleasure
  8. moon_tanner
    NW Florida
    Just an update,
    I put the old brake master cylinder in the prius, and the "Check Hybrid System" alert went away. Therefore, the problem was that the ECU didn't like the Lexus master cylinder, even though the part was supposed to be a direct fit.
    The old errors did return, but my original problem that started this post has been solved. Thank you!
    Image of errors after the old master cylinder put back in:
