2010 prius didn't start. Gradually lost all electrical over 1 1/2 hours with charger attached.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by wasilla1, Feb 15, 2022.
  1. wasilla1
    wasilla1 New Member
    alaska
    I bought a 2010 prius this past summer. I left it at the airport for 16 days and had to use a jump starter to get it started. I drove it home, adout 45 miles over an hour without a problem. The car sat for 3 1/2 days in 20 something temps.
    I initially got a green light on the start button, but nothing seemed to happen. I tried again after around a minute. I went to get a charger. The door was chiming when I got out and it sounded like an electric motor was going for a few seconds. When I got back, the radio was on, but the car was not. I hooked the charger up and the battery looked to have juice left. The arrow was between the 10 and 15. charged it while I read this forum. I went back out. The light was amber, but eventually went to green after repeated break pushes. Still didnt start. The taillights and headlights didnt work. The horn didnt work and I couldnt open the hatch. The interior dome lights were dim. After letting it charge for another hour or so, I came back out and nothing was working. No start button light, no dome light, nothing on the dashboard. A blizzard kicked in so I took the charger off.
    This morning I connected the charger directly to the 12 volt. The charger arrow didn't noticeably change from using the under the hood connections. Im currently trickle charging. I didn't notice any codes when the dashboard lights were working, but I wasnt specifically looking for one.
    The only dealership is around 45 miles away in Anchorage. Im not mechanical, but I had assumed that I could get a prius started. I was wrong. Any idea what the proplem is. I don't understand whats happening.
  2. wasilla1
    wasilla1 New Member
    alaska
    The battery is charging now., and lights are back. Im guessing, I can start it in the morning. Sorry if i cluttered up the forum
    51,120
    you likely still will need a new 12v
  4. Mendel Leisk
    40,562
    Check it's voltage for starters, say with a digital multi-meter.
    How old is it?
  5. ChapmanF
    17,294
    If the battery got seriously discharged, getting it back to full charge on a 'trickle' rate will take pretty near forever.
    Can you get your charger to use something more like a 4 or 4½ amp rate? That'll get the job done in 15 hours or so.
  6. PriusCamper
    PriusCamper Senior Member
    12,030
    4,888
    Pacific Northwest, USA
  7. wasilla1
    wasilla1 New Member
    alaska
    Thanks for the responses. The car starts. its miserable day outside, so i havent driven it yet.
    Im not sure how old the battery is. probably less than 5 years but more than 2. Ive been leaving the car for weeks at a time. Ive had to jump it once and use a charger 4 times.
    I guess I don't understand how chargers work. I had assumed that the needle on the gauge indicated that it was charging, but that wasnt the case and the outlet was dead. I trickle charged all night and the needle barely moved, still between 10 and 15. I followed advice and bumped up the amp rate, but the charger indicated that it was fully charged. Im guessing that means that the battery needs replacing. I don't have a multi meter. I understand that some places do free checks though. I'll probably go to a store that does installation too. Shipping large batteries to alaska tends to be problematic as most places wont ship here.
    If anyone is willing to suggest a replacement 12 volt carried by stores, or warn me off of one, id appreciate it. It will surely take a while to get an appointement at the anchorage dealership, but if thats the best choice, I can probably wait a bit.
  8. bisco
    51,120
    they are all fine. i like the oem if the price is reasonable
