1. The site is migrating to a new server this week, so there will likely be some downtime during that process. You can follow along here for updates.
2010 Prius head gasket and water pump. Any advice as to where to buy the parts?
Discussion in 'Gen 3 Prius Main Forum' started by Cameron Edwards, Jul 10, 2021.
  1. Cameron Edwards
    Cameron Edwards Junior Member
    Russell Springs, KS
    I have cleaned EGR system and intake manifold. It stopped using oil after I did all that, but just started using oil again. Now it seems head gasket is blown and been told it needs water pump.
    I have looked in the spark plug holes and it seems to be a LOT of carbon in cylinder chamber. Is it worth changing head? Would I be better off with replacement engine? What would the cost difference be?
    Car only has 115K
  2. wheezyglider
    wheezyglider Active Member
    247
    177
    SF Bay Area
    You need more diagnosis before you go leaping for the headgasket. In your situation the HG is not the top suspect.
    Using oil is usually a different problem from the typical early headgasket failure in this car. In that case, it more often leaks coolant into a cylinder. Oil consumption is more associated with valves and rings.
    Also, if cleaning your EGR stuff did anything to lessen oil consumption it would probably be because the PCV valve was sticking and you changed it?
    douglasjre likes this.
  3. Mendel Leisk
    Mendel Leisk Patron saint of newly poured sidewalks
    37,086
    Reading between the lines, someone has told you head gasket is blown? If so, who was that, and did they run some tests?
    Leak Down test is best bet I think, to check if head gasket is failing, and how it's failing.
  4. MilkyWay
    MilkyWay Active Member
    819
    357
    23
    MI
    Go on car-part, search "2020 Toyota Prius Engine" vin A or vin B. Buy and toss it in.
    You can get one with under 40k miles on it for the same price as a gen 3 with 150-160k miles on it.
    http://car-part.com
    https://attachments.priuschat.com/attachment-files/2020/02/182535_Gen_4_Engine_into_Gen_3_Prius_Partial_Guide_-_by_PriusChat_member_Alexander_D.pdf
Loading...
