2010 Prius (III?) purchase. First time hybrid owner
Discussion in 'Gen 3 Prius Main Forum' started by kazbach, Jun 21, 2021.
  1. kazbach
    kazbach New Member
    sa texas
    Hello! I have an opportunity to buy a 2010 Prius (I'm assuming it is a gen III) for $5,000. It has 50K miles. Leather. Clean. Seems like a pretty great deal, not knowing much else - if it is what it says on the tin. The owner recently died - probably unrelated :p. It is being sold by the estate.
    I've wanted a prius for sometime and am particularly interested using it camping/traveling and as a back up if the power goes out (like it did during the terrible freeze this winter in Texas).
    I'm about 90% certain I will be purchasing it but wanted to do some diligence since I've never owned a hybrid.. Here is my check list - what am I missing?
    - I understand the rings (head gasket?) may be a problem,in the 2010, so I will look for oil underneath/around and in the exhaust....
    - Check the details given on the fuel economy in the dash. I expect it to have gotten at least 40 mph.
    - Walking around, everything looks good. It has been garage kept - accept maybe the headlights which look foggy.
    - Take it for a ride. Kick the tires. Look underneath.
    - Turn on 'all electric' mode and see how far she goes - to test the ev battery.
    - It had been sitting for about 6 months - so the 'car battery' had to be replaced. Should I worry about the 'ev battery' - for sitting that long without running?
    - Check EGR and manifold (will need to find out more about those :)
    Am I missing anything? Advise? Warnings - what do you think?
    Thank you and see you out there! Kaz
  2. bettergolf
    bettergolf Active Member
    411
    332
    Sanford NC
    Well the hybrid battery is already 11 years old and it's not good for them to sit unused. Not sure if the fact that it's older makes it more sensitive to inactivity. Otherwise it sounds like a good deal. I just had a guy look at the 2015 I'm selling, he's driving a 2010 with 225k miles. He says it's now using a little oil but has had no problems since he bought it with 40k miles on it.
    kazbach likes this.
  3. davecook89t
    davecook89t Senior Member
    1,057
    789
    Washington State, Florida
    Four Touring
    If it's been sitting for 6 months, and you are fairly certain you will buy it, I'm not sure I'd want to stress the HV battery right away by running it in EV mode as far as it will go. That may be enough to push what could be a marginal 11 year old battery over the edge. Of course, if it lights the red triangle at that point, I guess you could choose not to buy it, and it may be better to know sooner rather than later that the battery needs replacement. I think my choice would be to pick up a code reader and see what Dr. Prius shows to get an idea how well the battery is performing before buying it.
    kazbach likes this.
  4. davecook89t
    1,057
    789
    Four Touring
    The fact that it's older definitely makes it more sensitive to inactivity. I think that has been fairly well established by all the Gen 2 HV batteries that died during the COVID shutdown.
    kazbach likes this.
  5. rjparker
    rjparker Tu Humilde Sirviente
    7,591
    4,449
    Texas Hill Country
    Take it to Sams Auto and have him check it before you buy. These cars can cost you more than $5k just in major maintenance. The price for a legit 50k car is good. Maybe too good.
    bisco, kazbach and davecook89t like this.
  6. Mendel Leisk
    38,232
    For a data point, our 2010 has 90k kms, in the ballpark of your prospect. It’s seen regular use though; no recent 6 month hiatus. It DID however sit on dealership lot (enclosed) for about 15 months when new.
    So sorta similar, and still champion, FWIW.
    One thing you mention: yours was garage stored, BUT has some headlight fogging. That typically takes protracted sitting in the sun.
    I would check it out, have a test drive and listen for odd sounds, look it over carefully, inside and out, and under, tires/wheels. Make sure there’s two key fobs, spare tire and jack, and so on.
    bring along a jump pack if you have.
    keep in mind 3rd gen requires some owner “involvement, namely cleaning the Exhaust Gas Recirculation circuit and intake manifold. Toyota’s got their head in the sand (or somewhere else…) on this, but yeah you’ll need to. Don’t leave it past 100k. Sooner is better.
    bisco and kazbach like this.
  7. kazbach
    kazbach New Member
    sa texas
    Thank you everybody! :p
    All good to know - and new to me. Maybe before he moved it here it sat in the sun. Thank you!
    I will be gentle with my test and look for the red triangle. And also pick up the reader + Dr Prius. How could I not get the Dr Prius :?)
    Sams. Gonna do that 100%. Thank you RJParker.
    Many many thanks to all. Seems like great advise.
    bisco, Mendel Leisk and davecook89t like this.
  8. kazbach
    kazbach New Member
    sa texas
    So, after some days of 'estate matters' I was able to go for a drive today, kick the tires, look underneath etc. Looks nice, remarkably so for a 10+ year old vehicle. No oil sitting underneath :0/
    The seller, because of 'estate matters'(where his lawyer told him he NEEDED to get another quote) got a quote from carmax. Says they would give him 6,500 - and willing to take 5,800 which is ok by me unless it is a lemon which I seriously doubt.
    I could see the battery was charging. We sat and ran the AC - then the engine turned on. When we drove, you could see the battery charging pretty rapidly. I forgot to look at the 'gas stats' but I will give that look before I buy. Pretty confidant it will be ok given the look/drive.
    RJParker - I called Sam's multiple times and got a voice box - which was full. I told the seller I'd like to take it there before we close the deal. I assume he can run Dr Prius and give me some experienced feedback on the matter - including a in depth look at the health of the battery. He has great reviews.
    It is a nice drive. Someone said it has 'nasa level engineering' - who am I to argue against that.
    Honestly, I'm kind of excited.
    Anyway, to all, happy Priusing! Thanks for all the advice. (hey look at me I spelled that right).
    Cheers, see you on the other side.
  9. kazbach
    kazbach New Member
    sa texas
    I went to Sam's. Truly great advice rjparker! Highly recommended. Thank you. He opened the hood and immediately pointed out the head gasket. I was told it was part of a recall fix. I have _copious_ documentation. No, the gasket just started leaking and was fixed in 2016. Part of the gasket is 'sticking out', not a great job IMO. ($2.5k from Toyota - I have to say they really rip you off, looking at the paperwork) .He took a pretty thorough look and said 'if you don't buy this for 5,800, I will'.
    So I did - and feel like I got a good/great deal. Very good. Aside from the driver side, you would think the vehicle was brand new. But not all roses.
    Sam did not do a full battery test - (he just said 'it was fine'). - at least did not do the things I had to do with Dr Prius. (fast start / stop etc) at the end of the day Dr Prius had no codes thrown (I was beginning to wonder if the 'battery test' was even going to work but it ultimately said it was fine. The 'longevity test' - charge/discharge said the battery had 62% capacity. Not a number I would have hoped but one that would not have changed my mind in buying it.
    My first day, I took it for a drive of 45 miles, after filling up. Got back, filled up, it used .8 gallons. Wow! I'm happy about that! I feel confidant I will get well above 40 on a full tank. Maybe fifty.
    I can see myself getting 'gauge syndrome' while driving this thing. Lots of interesting functions and doodads. I'll have to ween myself from it but it honestly does interest me - driving aside.
    One thing that does perturb me, perhaps the only thing, is 1) The EV mode simply does not work for any distance 2) Running the AC, the engine cycles a little too often. Of course, this might be expected given 62%. Sam says he reconditions them for 500 - back to 90% of capacity so I will have to put that on my list of Todos. He said, come back and I will show you how to fix the traction battery fan (which runs all the time and is pretty loud). Honestly though, I have some experience with LifePo4 and may jump to it in a year or so. I know there is some gray area there among the community but it seems the obvious choice to me.
    My first mod is complete. It used all the technical prowess I could muster and I only fell on my butt once. I took off the hubcaps :p
    My todo list.
    1) Change oil/filter (not done since 2019, but still have miles to go ... but still ...)
    2) Put on a (tiny!) lift kit (so I don't pull off fenders on dirt roads and speed bumps)
    3) Fix some dings and scrapes
    4) Fix the traction battery + fan
    5) At least take a look at the EGR and intake with a mechanic who knows what to look for.
    Anyhow, just wanted to give an update because I know everyone was waiting anxiously LOL. I really do appreciate the feedback. I'm sure I will be back with more questions. High five to all.
    Cheers, Kaz
    #9 kazbach, Jun 30, 2021
  10. bisco
    48,962
    congrats!
    prius are not meant to be driven in ev much, it hurts your mpg's.
    engine cycling is normal. the amount varies, depending on how you're driving, temp and humidity.
    all the best!(y)
  11. Grit
    Grit Senior Member
    6,113
    4,040
    Wilkes Land
    o_O
  12. kazbach
    kazbach New Member
    sa texas
    In the owner's defense, he was dying. In terms of miles, the little Toyota sticker for oil changes says I have a couple thousand miles to go. I'll change it soon, I promise (y)
  13. Grit
    Grit Senior Member
    6,113
    4,040
    Wilkes Land
    oil 2 yrs old, and will change it soon? o_O
