2010 Prius Keyless Entry Door Unlock
Discussion in 'Gen 3 Prius Main Forum' started by imagehh, Oct 11, 2009.
  1. imagehh
    imagehh New Member
    West Covina, CA
    Do any of you know if Toyota dealer can change the keyless entry setting on a 2010 Pruis? When I enter the car from the driver side, only the driver side door unlocks, but if I enter the car from the passenger side, both doors unlock at the same time. Can the dealer change the setting to both doors open entering from the driver side?
  2. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    You can change it yourself in a few minutes.
    In my Owners Manual its under "switching door unlock function" on page 48
  3. Tideland Prius
    16,014
    Yup you can have it changed to global unlock for any door or local unlock at any door or the default which is what you described (local for driver, global for the pass. and the hatch)
  4. GoGreenTreeHugger
    GoGreenTreeHugger New Member
    37
    Bakersfield
    Hi. Um when I get into my new 2010 prius iv, well go up to one of the doors I should say. If I go to the passenger door just that door unlocks if I go to the trunk just the trunk unlocks but if I do to the drivers door all doors unlock.
    THANK YOU!
  5. Tideland Prius
    16,014
    ??? That setup doesn't exist in any Toyota vehicle.
  6. imagehh
    imagehh New Member
    West Covina, CA
    It worked! Coolness! It is on page 48 in my US manual. Thank you so much from saving me a trip to the dealer! :)
  7. GoGreenTreeHugger
    37
    Bakersfield
    Yea I know. The two keys that came with the car work like everybody elses but the three spare key I naught were not set and I didn't know how to set them so my friends dad owns a car shop that makes coustom things for cars did it for me and that's the way those three work.
    I do apologize I should of talked about wich keys. Sorry about that.
    THANK YOU.
  8. benatwhodotnet
    benatwhodotnet Junior Member
    Glendale AZ
    It also worked for my new 2010 2, but now THE ALARM SOUNDS EVERY TIME THE DOOR IS OPENED. The locks all unlock and a second later, after the driver door opens, the alarm starts. It does not stop until I hit the unlock button on the key fob. I have to go back to the dealer on this one.
  9. Tideland Prius
    16,014
    Yeah that's the dealer's problem. You probably had a dealer-installed alarm system, right?
