2010 Prius - Rattle in the passenger side dashboard area
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by sugarfreejones, Sep 21, 2019.
  1. sugarfreejones
    sugarfreejones 2010 Prius 3 Owner
    Austin, TX
    A high pitched rattling sound recently started around/behind the passenger-side dashboard area of my 2010 Prius. It is not related to the AC, and only happens when I am stepping on the accelerator. It’s really noticeable when I hit about 30mph.
    Here's a video that tries to capture the noise - it's faint but listen for the high-pitched noise:
    My car only has about 50k miles on it, and replaced the 12v battery about 6 months ago.
    Any help appreciated!
    Rob
  2. spiralhelix
    spiralhelix Active Member
    255
    216
    Illinois
    i had to turn up my stereo really high to hear it and it was still really tough to make out the sound, but i haven't the slightest clue what it could be.
  3. bunny45
    bunny45 New Member
    Germany
    Hi sugarfreejones,
    greetings from Germany. Has this rattling noise only started recently? Has the area you live in experienced a temperature drop recently?
  4. sugarfreejones
    Austin, TX
    I found this thread yesterday. Sounds like the problem! 2012 Prius With Passenger Area Slight Rattle | PriusChat
    one comment was:
    I've got the same rattle I believe on my 2011. I drove a 2010 Prius that was in the shop for the same rattle, theirs a lot worse than mine, it was diagnosed as the glove box strut (right side holding the glove box open). I've been since playing around with it on my own vehicle...cannot tell if that is exactly it or not. I wasn't able to drive the other Prius after the repair. That's what a tech told me. Mine only happens when cruising on EV power, then slightly pushing the gas pedal, the ICE turns on, the rattle will appear, 20-35mph. Only when pedal is pressed slightly. Rattles are the worst.
    This totally sounds like my problem. A few weeks ago I opened the glove box for the first time in a long time, and the problem started soon after. Gonna check it out today.
  5. Boffin
    Boffin Member
    43
    65
    Maryland
    This is a fairly common problem with the 2010. I've just learned to live with mine. A TSB has been issued for it:
    T-SB-0064-12
  6. JC91006
    16,470
    8,383
    Remove the strut and see if sound goes away
  7. bunny45
    bunny45 New Member
    Germany
    If it's not raining by the time I get home this evening, I'll try to post some pics showing how to solve the issue. It drove me nuts until I solved it.
    orenji likes this.
  8. bunny45
    bunny45 New Member
    Germany
    Open the hood. Just ahead of the right-hand hood hinge you'll find a plastic access panel that you can remove with the aid of a thin flat screwdriver. The yellow thing in the photo is a Scotchbrite kitchen sponge withe a green scouring pad on the other side. I folded the sponge and wedged it between the outer panel and the strut. Sounds complicated but isn't. The rattling sound that I encountered in colder weather and at low RPM disappeared immediately. IMG_20190923_181914.jpeg IMG_20190923_181938.jpeg
    CR94 likes this.
  9. JC91006
    16,470
    8,383
    I had a similar "droning" sound when I started my car, there was a tsb that mentioned it was a failed motor mount that caused the issue. But I think what you've done mashed more sense
