2010 Prius With Low Engine Coolant, No Interior Heat - Should I Buy?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jumpinjivinjoe, Oct 11, 2017.
  1. jumpinjivinjoe
    jumpinjivinjoe Junior Member
    Kennewick, WA
    Have an opportunity to buy another 2010 Prius for $3,850. It seems to run and drive great, however there are a few problems which concern me.
    Upon driving, the engine coolant overheating light turned on. Turns out that the engine coolant reservoir is out of coolant. Obviously it doesn't just evaporate, it must have leaked out somewhere. I could not identify where though. I would be concerned it might have a head gasket leak but it didn't lack performance like I would suspect with a head gasket issue.
    I also plugged in my TechStream and did a health check on got the following codes:
    P0037
    C2123
    C1241
    B1503
    What would cause the engine coolant to be so low?
    Might there be damage if he's been driving it with low coolant levels?
    Should I be concerned with the ECU codes?
    Should I go for it or look for a better opportunity?
  2. JC91006
    16,470
    8,383
    Do NOT buy. If this thing has overheated, it most likely has a blown head gasket
  3. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,476
    Bay Area, California
    2019 Prius Prime
    There are plenty of Prius fish in the sea(y).
    amos, mjoo, m.wynn and 1 other person like this.
  4. Bill the Engineer
    1,044
    2,272
    467
    At the beach in Delaware...
    DO NOT BUY! Blown head gasket!
  5. Mendel Leisk
    38,242
    How many miles on it, just curious.
    mjoo, m.wynn and Raytheeagle like this.
  6. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    i bought one like that for 2k.ended up replacing engine
    m.wynn and mjoo like this.
  7. jumpinjivinjoe
    Kennewick, WA
    Wow! I appreciate the advice! We decided against getting this Prius. I can deal with engine trouble codes, but overheating and no coolant is just too risky. It had 236,000 miles.
    Thank you everyone!
    Aaron Vitolins and Mendel Leisk like this.
