2010 Pruis II, with 54k Miles has Bad Inverter. 3-4 week wait
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jamesdanielharkness, Sep 21, 2015.
  1. jamesdanielharkness
    jamesdanielharkness Junior Member
    Fredericksburg, VA
    My 2010 Pruis II, not Two as it is a 2010, has the dreaded Check Hybrid System. Took it to Toyota, and the inverter has failed, and there are no parts available. 3-4 week wait! We had the software recall done on this car last year which was suppose to fix this. I'm not happy. We have a 2006 Pruis that is rock solid. What is going on? Is this problem widespread? Is this why there is no parts?
    Jim
  2. JC91006
    16,468
    8,383
    So do you get a rental car?
    Do you drive the car hard?
  3. jamesdanielharkness
    Fredericksburg, VA
    We did get a rental, and no we don't drive the car hard.
  4. HGS
    HGS Member
    307
    122
    Are they repairing it under warranty? I believe the inverter is part of the 8 year/100,000 mile warranty, but not sure.
    I don't think that part fails very often. That's probably why there's a wait. For those out of warranty, the inverter can be bought used with good results. The inverter usually fails after an inverter cooling pump failure when the inverter overheats,
    How long have you owned the car?
    #4 HGS, Sep 22, 2015
  5. jamesdanielharkness
    Fredericksburg, VA
    They are repairing it under warranty. We have the base warranty on this vehicle. We have owned the vehicle since new.
    Here were the symptoms. Prius showed ready with check hybrid system. When you try to drive it, you can go slow, but if you try to accelerate, the engine revs high, and it feels like the transmission is slipping. All four master alarm LEDs were on.
    Jim
  6. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I had an inverter fail at 70k miles, albeit before the recall.
    What symptoms did it give before failing? Did it drive at all after or was it just a paper weight? How did you get it to the dealers?
  7. jamesdanielharkness
    Fredericksburg, VA
    No symptoms before failure. It was drivable at slow speed, and made it to the dealer. As I mentioned above, if you tried to accelerate, the engine would rev high, and it felt like the transmission was slipping.
    Jim
  8. HGS
    HGS Member
    307
    122
    Good to hear they are fixing it under warranty. It's a shame you must wait weeks for the repair.
    I believe it's just an unlucky failure. Inverters are not failing too often.
    When JC91006 asked about a rental, I though he wanted to know if you bought the car used from a rental car company.
  9. jamesdanielharkness
    Fredericksburg, VA
    No. They gave us a 2015 Camry as a rental from Enterprise Rental Car.
    Jim
  10. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Sorry to hear about your failure and wait time. At least it is covered under warranty and you have a rental.
    As part of the software recall Toyota extended the warranty on the Inverter Power Module (IPM) to 15 years. The IPM is a sub-module inside the Inverter Module and contains the power semi-conductors. The software modification was meant to reduce the rate of rise of current flow through these power components to help prevent failure.
    Don't you have elevation changes around Fredericksburg? If so this could put a strain on the IPM more so than flat terrain. Yours may have been fatigued prior to the software recall, assuming that it may be the IPM that has failed.
    Toyota has been replacing quite a few of these units and most have had a similar wait time as you.
    Do you know whether the dealer says the failure is the Inverter Module or the IPM?
    Good luck.
  11. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Did you use Power mode at the time or use it often? My inverter failed when in Power mode and I'd been driving the car briskley for about 20 miles.
  12. jamesdanielharkness
    Fredericksburg, VA
    I believe it was just the inverter that failed. The topography in Fredericksburg is rolling hills. I do not use power mode. We set it for Econ, and leave it there.
    Jim
  13. Starship_Enterprius
    Starship_Enterprius Active Member
    312
    152
    Ottawa, Ontario
    2018 Prius Prime
    I'm beginning to see a pattern. I've read in other posts their inverter failed accelerating towards the next hill right after regening down another. Seems like the spike between regen and acceleration fries something in the module.
    jdcollins5 likes this.
  14. HGS
    HGS Member
    307
    122
    I think for the most part, driving conservative, normal or hard is not going to change the wear and tear on the inverter. I don't believe your driving style made a difference.
    My 2013 Prius has 47,000 miles and I'm driving near 20,000 miles/year mostly on the expressway (50 miles each way to work). I hope it lasts until 200,000 miles without a major repair. But if the inverter needs replacing before hand (out of warranty), I've seen used ones for about $400-500.
    That cycle happens several times on a typical drive. Here is a picture of the inverter temperature up to 140 F. I see the temperature move quickly up and down every time it turns on and off.
    #14 HGS, Sep 22, 2015
    jamesdanielharkness likes this.
  15. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    That's how mine went. Enthusiastic driving for 20 miles, down a long gradual incline which then went really steep for 1/4 mile before stopping at the bottom. Set off again at the bottom, floored it to overtake a truck and pop - no inverter.
    To risk duplicating what I've said elsewhere, roughtly a couple weeks or a month earlier the car made a loud and high pitched noise coming down that same hill. It was the same frequency as the normal Prius high pitched noise when braking, except it was loud enough for be heard over my music - which was loud! it lasted about 5 seconds. At the time I didn't know what it was, but with hindsight...
    #15 GrumpyCabbie, Sep 22, 2015
    Starship_Enterprius likes this.
  16. Mendel Leisk
    38,198
    Do you know if that is for all owners? I recall (here) a few US owners got letters informing them their inverter warranty was extended to 15 years, but just case by case?
  17. jdcollins5
    5,131
    1,338
    Wilmington, NC
    I do not know. I received the letter and you are correct that it stated it was on a case-by-case basis based on VIN and not open like some others.
    Other than the testing Toyota did during the software recall I am not sure how they determine who gets the extended warranty and who does not!
    I have not heard of anyone on here having an IPM or Inverter failure that has not been covered by warranty, though, have you?
  18. Mendel Leisk
    38,198
    Nope, without the extension, the Canadian warranty is 8 years or 160,000 km, so good for a while yet. 15 years sounds better though. :)
  19. HGS
    HGS Member
    307
    122
    At my annual mileage rate I will be 100,000 miles at only 5 years old. If the need arises, I'll just have to buy a used one and install myself after the warranty. I have no worries though.
    If the problem is stress/heat cycles on the electrical circuits in the inverter, perhaps my 35 to 50 mile expressway drive to work will not be too much stress. While monitoring the inverter temperature, I see it jump from 115 F up to 165 F sometimes. It happens within a few seconds of coming on, then quickly goes back down after it stops working/charging. The coolant temperature stays fairly constant. See post #14: coolant temperature 100 F and inverter 140 F.
  20. Mendel Leisk
    38,198
    Wonder why does the inverter warranty extension fairy only bless some of us??
    Are you monitoring inverter temp with an XGauge on Scanguage? I should look into that.
