2010 stock wheels
Discussion in 'Gen 3 Prius Main Forum' started by gw2002, Jun 25, 2010.
  1. gw2002
    gw2002 New Member
    Baton Rouge, LA
    Bought a 2010 Prius II around Feb. 1. So far, so good. No real problems, except the right rear wheel cover fell off sometime around mile 2500.
    To my delight, the missing ugly wheel cover revealed a pretty good looking allow wheel underneath. Except the alloy has a gaping, empty hole in the center of the wheel. Rather than pay a king's ransom to replace the lost wheel cover, I asked in the dealer's parts dept. if an OEM center-cap was available to fit the Prius wheel. YES! Turns out there is, so I ordered 4 center caps for less than $60. They arrived about a week later. Plugged them into the holes, and away we go with good looking alloys now instead of those beastly wheel covers.
    Has anyone else gone this route with your wheels?
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
  3. rpeek2
    rpeek2 Dry Ice Juggler
    149
    MidwayUSA
    Many, including my self. Agree with you on the duct tape over stained glass approach to the wheels. Its like a treasure find when you pop those cheapie covers off to reveal what never should have been covered up. Do a search for "wheel centers" if you are interested in what others have done.
  4. skamar
    skamar Junior Member
    16
    Greece
    The first thing that i did when i took my new baby was to put out the ugly wheels covers. And i bought these from the Toyota dealer for 60,00€.
  5. exbauer
    exbauer Active Member
    1,188
    102
    Washington
    oh how beautiful the rear tail light looks without the red reflector on the side.
  6. Fstr911
    Fstr911 Member
    235
    55
    I didn't even save those plastic wheel covers. After seeing the alloy wheels I realized it was time to send them to the plastic recycle pile. And the the Prius is much faster now....smile
  7. Bruno_S
    Bruno_S New Member
    130
    68
    The aerodynamic impact of removing the wheels is not known. Your MPG may increase if you remove the plastic wheel covers.
  8. RRxing
    RRxing Senior Member
    2,558
    1,833
    NEPA
    Or decrease. The effect the wheel covers have on mpg has to be so small that it isn't even on my radar.
  9. Fstr911
    Fstr911 Member
    235
    55
    The MPG did not increase or decrease after my plastic covers were removed. And IMO those plastic covers are butt ugly and cheap looking.
  10. Kennewick Man
    Kennewick Man Junior Member
    42
    Kennewick,Wa.
    X2.............:rockon:
  11. fuzzy1
    10,603
    The PC regulars invited to the prerelease events ~15-18 months ago, who were able to talk directly to Toyota engineers and staff, indicated that the covers did increase MPG. The magnitude was not publicly quantified, but Toyota was having to squeeze many things ever so slightly more to achieve that landmark 50 MPG EPA label, instead of a 49.
    If removing the covers would increase MPG, I can't believe Toyota would have left them on.
  12. GreenClipper
    GreenClipper Senior Member
    116
    Tulsa, Ok.
    I've had my Prius for 7 months now and one of the first things that I did was remove the ugly wheel covers. Don't know why Toyota thought they needed to be on there, don't care! I'm more concerned with their "tweeking" the onboard MPG calculation,.....some say 6% descrepency. To me it looks like that was their easiest fix for getting 50mpg! If they make a negative difference in my FE, then so be it, as they are "BUTT UGLY"! If those alloys hadn't been under them, I'd have been buying aftermarkets for it. Either that or I would have held out for the V I really wanted, most of which were not coming to this part of the country! :)
  13. Bruno_S
    Bruno_S New Member
    130
    68
    Sorry I meant decrease MPG. I agree, the main reason the wheel covers exist is to make the car more efficient. I actually removed the front license plate to make the car more aerodynamic.
  14. fuzzy1
    10,603
    The display discrepancy has no connection whatsoever to the EPA label.
  15. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
  16. Bruno_S
    Bruno_S New Member
    130
    68
    I live in La Jolla CA where Ferraris are common. In fact, the town only has two dealerships a Ferrari-Maserati and Lamborghini-Bentley. There are Prius all over. If you pull into one of the fancy restaurants in any other "economy" car besides the Prius people will probably think you work there. Last Sunday I was at the gas station and a black Gen III Prius pull in with black 18-inch wheels. It also had pimped front and tail lights. Although I cannot exactly say what was done to them, they look different. The car looked amazing. I wouldn't be surprised if Gen III after market spoilers and other parts become available to cater to these markets.
  17. ozarkgolfer
    ozarkgolfer Junior Member
    76
    Rogers, AR
  18. BassMasterCHS
    BassMasterCHS New Member
    Swamps
    yeah they won't affect anything at all.. but if you spray paint them...
