2011 Matrix XRS 18" wheels
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Much More Better, Feb 3, 2011.
  1. Much More Better
    Much More Better Active Member
    655
    163
    They are sweet! Maybe some day when my 15" winters are worn, I'll use my 17" OEMs for winter and 18" for summer.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Wonder what the weight is?
  3. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
  4. peterjmc
    917
    188
    Clarksburg, MD
    I want to put the 20" Venza wheels on my Prius
  5. Much More Better
    655
    163
    I thought of Five Axis too. I just don't like all the pre-drilled holes.
  6. HI MPG
    HI MPG Active Member
    789
    133
    93
    Orange County, CA
    My thoughts exactly... too many lug holes distract from a clean rim.
  7. jukeboy
    jukeboy New Member
    132
    SGV, SoCal
    FYI, the XRS wheels have the 5x4.5 bolt pattern, ours is 5x4
    (I used to own a Matrix and still frequent their forums)
  8. Much More Better
    655
    163
    That is a surprise!! I always thought they were all the same. Oh well......
    Thanks.
  9. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    673
    179
    Vancouver, WA
    Here is what a the 16" wheels from my 07 Matrix XR would look like. I just wish they weighed less. They are 8 lbs more with the tire on it than my stock 15" wheel/tire.
  10. mmcdonal
    mmcdonal Active Member
    666
    98
    16
    Columbia MD
    Good luck turning those beasts! :)
    I had an '09 Venza with the 20's, and it was a drag to turn that thing, even on a highway ramp. It was AWD, so maybe that had something to do with it.
  11. Genoz World
    Genoz World ZEN-style living
    797
    La Canada
    I'M spending more time looking at your background posters than the rims! Cheers.
  12. SDM44
    SDM44 SeƱor Member
    199
    38
    Los Angeles
    Those 16" wheels look good on the car, but the fender gap is killing it. With those wheels you need to lower the car to close up that gap. Also, there's a little too much meat (sidewall) on those tires for my taste, but that's me. Otherwise, the design/look is nice.
  13. unkprius
    unkprius Member
    152
    Probably it's still jacked up a bit. Nice wheels though, look clean.
  14. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    Even some 17"-wheel Prius owners make the same mistake by using 215/50-17 tires instead of 215/45-17 in order to "close" the gap but then the tires look too fat.
