2011 Prius Gen 3 Very Quiet Knocking at Low Speeds (Video Included)
Discussion in 'Gen 3 Prius Main Forum' started by Jameson Babb, Jun 7, 2019.
Tags:
  1. Jameson Babb
    Jameson Babb Junior Member
    Hello all. Have owned my 2011 Prius for just over 3 months now. It has 120k miles. It just recently (last week or so) started making this very quiet knocking sort of noise when traveling at low speeds. As soon as I get above 11-12mph it goes away. It happens regardless of if I’m running on electric or gas motor. My oil levels seem to be OK and clean. I had a 2nd Gen 2007 before this and do not remember ever hearing this noise. Any thoughts or ideas? Thanks for the help!
    52,544
    could be your brake actuator, 3 way coolant valve, or hvac vent flap
  3. BZzap!
    BZzap! Senior Member
    1,607
    878
    Sounds like it’s wheel speed related. Very reminiscent of a CV joint knock or brake pad knock. Do you live in the Rust Belt by chance? You would be wise to take it to your local mechanic and have the brakes and front suspension inspected.
  4. Mendel Leisk
    42,055
    Check the tires? For example: you ran over freshly painted lane marker, and there's residue making a bit of sound, till it scrubs off.
