2011 Prius HID Relay Issue
Discussion in 'Gen 3 Prius Accessories and Modifications' started by bens1088, Sep 5, 2011.
  1. bens1088
    bens1088 Junior Member
    sf
    I have read almost every thread on priuschat and I cannot seem to figure out how to install the HID relay on a 2011. The fusebox is different from the 2010 to 2011 model and that little cover that has the white wire (coming from what I believe is the battery) does not provide useable power?
    Has anyone with a 2011 successfully installed an HID relay via the fuse box without splicing/tapping?
    Thanks
  2. unreal
    unreal Junior Member
    74
    SoCal
    Y do you need a relay? I just installed an HID on my 2011 and I didn't need to tap on anything..
  3. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    What wattage is your HID kit? If 55 Watt you won't need a relay. Are all your high amperage fuse spaces taken up? in my 2010 I have a couple of spare spaces with a blade sticking up that I could connect a relay wire to. You have to make sure you ground your relay.
  4. bens1088
    sf
    I need a relay because the HID's are flickering. That's a sign that the ballast isn't getting enough power and can/will shorten the life of your bulbs/ballasts. Already blew out one ballast.
    Plus we are switching to OEM ballasts which are extremely reliable, expensive, and sensitive. They will cut out of they aren't receiving enough power to prevent damage to themselves.
    How do you know the fuse ratings on the blank spots? Theres black spaces but no amperage ratings on the fuse guide.
  5. Feri
    Feri Active Member
    761
    144
  6. bens1088
    sf
    Hmm... Okay. I will take a look. I don't have the car with me right now but can any one who has a 2011 verify there are any open slots?
    Thanks for all your help!
  7. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    I wish I could help but my Genii is set up differently. Good idea using the relay. I always recommend using them on aftermarket HIDs.
  8. unreal
    74
    SoCal
    Theres actually 2 spots, the other spot I used for my foglights and that leaves me with one left on my 2011...
  9. bens1088
    sf
    it flickers even with the relay installed... what is going on... ive tested 4 different hid kits...
  10. Feri
    Feri Active Member
    761
    144
    Hi bens1088,
    I'm no expert. Have you tried a canbus ballast? I.e. a ballast that is specifically set up for operating with the canbus. Then you wouldn't need a relay. There are also canbus decoder modules whuch can be put in line with your original HID ballast ( point-blank.com.au ). I know Phillips produce canbus ballasts for 35 watt.
  11. bzyrice
    bzyrice Active Member
    805
    324
    West Palm
    if you have tried that many kits there maybe something you are doing wrong installing them.. different bulbs everytime? It can be the bulb that is making it flicker? Different ballasts everytime? Are both flickering? Or only one side? I have installed ALOT of kits (I used to sell them) and always found that flickering bulbs are caused by the ballast.. not a power draw issue... do your regular bulbs flicker? Are your connections all in? Are you using te same brand of kit? too many variables to figure out what is wrong.
  12. gust242
    gust242 New Member
    23
    hobart IN
    Hello
    All is there a easy way to get to the passenger side head light ? looking at the head light housing there's 3 bolts that I can see I'm hoping that if I remove them the hole thing will come off and make it easy as I am debating on a relay just to be safe thinking of the ddm tuning kit at 6000k on my 2011 3 any feed back ?
  13. Koocuz
    Koocuz Junior Member
    I could use some advice as well, I have a set of 5000K Apexcone HID's (very exited!) and I am torn, I understand why you would want a relay system (Protect OEM wire harness in case of extreme ballast failure, and Canbus, Other Circuitry?).
    Here is the thing though, the Halogens are not exactly "easy on power" and the factory harness should handle 35W HID's no problem. I am thinking instead of relays I will install a 10A fuse on each light just before the ballast. That way if it even thinks about surging or frying the fuse should pop.
    Thoughts, Comments? Overkill? Just install them already? :)
    Does anyone know if the power is a direct path to battery? Would a crappy/failing ballast possibly damage any prius systems/computers if not on a separate power line?
    Lastly if a relay is used will the lights work normally without "fake resistance", I am hoping the prius is not that smart. Canbus can be a serious pain on german cars...
    Thanks
  14. Koocuz
    Bump Anyone?
  15. bzyrice
    805
    324
    West Palm
    I wired mine without a relay and without any fuses.. I've had mine on this Prius for close to 6 months.. I had my hids on my old Prius with the same setup for almost 2 years and no issues.. I think u will be fine..
  16. xliderider
    xliderider Senior Member
    7,842
    3,099
    Honolulu, HI
    If you already have a relay it won't hurt to use it.
  17. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    I've had my HID's for over 6 months now- 35 watt ballasts.
    No relay- no problems. You're still using the factory harness- which is fused- to power the ballasts, so if the ballasts go bad and draw too much- the oem fuse will blow as it's designed to do.
    IIRC- the 35 watt ballasts draw less current than the OEM halogen bulbs anyway.
  18. U2NVME64
    U2NVME64 Junior Member
    77
    25
    I have a 2013 Prius and purchased the Morimoto HID kit. It came with a relay and new projectors. I want use the relay just to be on the safe side, no one appears to know how to hook up to the battery for power. Any help would be cool..
