2011 Prius IV Having Trouble Getting Air In / Breathing Can't Figure It Out
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Frank MM, May 16, 2025.
  1. Frank MM
    Frank MM Junior Member
    16
    Hello All,
    I'm a long time lurker on Priuschat and never had the need to post. Any problems I've had (nothing major) were addressed here previously so all I had to do was refer to past postings.
    I own a 2011 Prius IV that I purchased when it had about 165,000 miles on it. It now has about 230,000 miles on it. I'm a maintenance fanatic in general, so I've done quite a bit of work since my ownership started. The car has been really good to me.
    Thank you to everyone on here who freely contributes their knowledge. There is a wealth of information in previous postings, which is a good intro to this, in all honesty.
    Here is my current problem. I welcome any input, and would appreciate any troubleshooting tips if nothing else, so I can at least narrow down what the problem might be.
    My mechanic doesn't even want to think that his shop caused this, so I'm going to a new mechanic on Monday and I hope to give him some sort of starting point at least. Of course, I'm quite curious myself.
    Here we go.
    I brought the Prius to my long time mechanic to have the following work done:
    Replace PCV Valve
    Replace EGR Valve
    Replace EGR Cooler
    Replace EGR Pipe
    Clean Intake Manifold
    Clean MAP Sensor
    Clean MAF Sensor
    The good news is the mechanic only touched those things so my problem is somewhere in there.
    The bad news is the mechanic touched all those things so the problem could be any of those.
    Thanks to this sub, I learned about the EGR issues with this generation of Prius, and decided to just replace everything instead of trusting the mechanic to clean the old parts properly. I do have them and have to get around to cleaning them sooner or later, but the car sure needed the servicing.
    So on to the problem.
    About 3 days after I got the car back, I noticed the car started to idle quite rough. It definitely sounds like it is struggling to take air in.
    My MPG also went down from about 48mpg on average to about 38mpg on average, with no change in driving habits, route, nothing. Certainly nothing that would cause a 10mpg drop. Quite annoying because I was hoping the MPG would go up not down with the EGR service.
    Things I noticed while trying to solve this:
    If I disconnect the 12v battery to reset the computer, the rough idle will go away for about 2-3 days (not sure if this is a function of simply time or how many times the car is started) but the MPG drop remains.
    The rough idle only seems to happen when the engine is charging the traction battery, so when the battery shows about two bars.
    I recorded the actual idle sound but can't post it yet because I don't have enough posts and I didn't want to "cheat." If someone can allow me to before I reach the posting amount that would be awesome, or I can just wait until I get there.
    It is definitely NOT the head gasket, knock wood. That is obviously a very distinct sound, and I listened to it on youtube from several sources. The sound all sounded the same, and the sound my car is making is absolutely NOT that sound.
    My sound definitely seems to be tied to having trouble with air and/or breathing.
    So that's my issue. I'd appreciate any thoughts, definitely. If more info is needed or any questions please ask.
    Be gentle, lol. I hope I'll be able to give back many times over.
    Thank you everyone.
    Sincerely,
    Frank
  2. Frank MM
    16
    Oops, I forgot something. It's not throwing any codes.
  3. Brian1954
    Brian1954 Senior Member
    2,425
    973
    South Central PA, USA
    The new parts that the mechanic installed, are they Toyota OEM parts or aftermarket parts?
    Do you have a scanner to check short and long-term fuel trims?
    Was the throttle body cleaned when it was off?
    #3 Brian1954, May 16, 2025
  4. Leadfoot J. McCoalroller
    8,155
    7,657
    Pennsylvania
    2018 Prius c
    might also be worth using ^ scan tool referenced above ^ to see if the roughness correlates with open loop/closed loop changeover
    Brian1954 likes this.
  5. bisco
    52,431
    are there any trouble lights?
    is the air filter box connected properly?
    any loose connectors in the areas of work done?
  6. Frank MM
    16
    They were aftermarket. I buy almost all my parts from Rock Auto, and I don't buy cheap parts.
    The mechanic I'm going to on Monday has a scanner. Not sure what fuel trims are, but I'll look it up on here.
    Yes, I forgot that one, sorry. The throttle body was cleaned as part of the other work I posted.
    No, no lights. Yes to the air box.
    Haven't seen any.
    Ok, I'll look up that term. It's over my head.
    #6 Frank MM, May 17, 2025
  7. Frank MM
    16
    I can post a link to the noise in my next post! Yay! Hopefully will be able to do so in the morning. It isn't "counting" my posts yet. Thanks to everyone that responded so far.
    I don't know why, but I was thinking it might be the MAF sensor. I was going to have the mechanic on Monday check the voltage on it to rule it out, if nothing else.
    No? Yes?
  8. Mendel Leisk
    41,957
    At what miles did you do that, and was it the first cleaning (well, replacement) of the EGR system?
  9. Frank MM
    16
    Well, I just did it 2 months ago to be honest. I didn't even know it was a "thing" until this board. So at about 210,000. So far, before and after, all seems good. I just need the car to last me until January. Long story. But at that time I have to get a newer one no matter what.
    I'm guessing it was the first time, or rather assuming. I got the car when it had 165,000 miles or so. I don't know if any prior owners did it, but I do know the one before me kept the car really well, which is why I purchased it.
    #9 Frank MM, May 17, 2025
  10. Frank MM
    16
    I still can't post the link. It says I only have 3 posts, what do I need to do? I want you guys to see the sound. If you go on youtube and search for user "frankm759" it's my only short. What qualifies as a "post" here? Any help is appreciated.
  11. Frank MM
    16
    Oh, does anyone have any info as to what a "correct" short and long-term fuel term reading should look like? And just for my own sake, how it's adjusted? Sorry, I sincerely never heard those terms before, forgive me.
    I have to see what this means I have no idea.
    #11 Frank MM, May 17, 2025
  12. Tideland Prius
    16,624
    It has to be approved by a moderator to count. It is a way for us to control spam.
    You should be able to post a link now.
  13. Leadfoot J. McCoalroller
    8,155
    7,657
    Pennsylvania
    2018 Prius c
    short version:
    Open loop = engine not warmed up, the fuel injection system is not trusting certain sensors for guidance on how much fuel to inject, instead it is using a "canned" predictive recipe.
    Closed loop = engine warmed up, system is trusting its sensors to modulate the fuel input based on what the previous cycle just did.
    You can use a scan tool to show you in real time whether the car is in open or closed loop mode, and sometimes this can help you narrow down the issue.
    CR94 likes this.
  14. Mendel Leisk
    41,957
    How did the interior of the EGR Cooler look? You managed to clear it? How about the small diameter EGR passages, one per intake port, on the intake manifold?
  15. Frank MM
    16
    Before I went ahead and did it I read all about the process on here and the experience of others. I spent probably too much time doing this, though perhaps most of you wouldn't think so. :)
    I didn't want to take any chances with trusting a mechanic's idea of "clean" or risk it not being done properly, so I actually had all new parts installed instead of cleaning the existing. I have the old parts, I am sure they are fine, they just need a cleaning. Once I'm sure I don't need them any longer, I was actually thinking about offering them on here to whoever wants them. Free, no cost. I would just want the shipping cost covered.
    So the above means I put on a brand new EGR Valve, Cooler, and Pipe.
    wukong sun likes this.
  16. Frank MM
    16
    Well, here is the moment you've all been waiting for, I'm sure. The actual problem recorded. So here it is. Reminder, this specifically occurs when the traction battery is down to about two bars and the engine kicks on when stopped (at a light, for example) to charge it. I hope this helps to better identify the problem. Hope isn't a strong enough word. And to everyone, my continued appreciation helping me with this, I assure you.
    PS - That little black box I found on Amazon. There's fire powder in there. If there is ever an engine fire it's supposed to explode and put the flames out. Here's to hoping I never find out if it works or not.
    - YouTube
  17. wukong sun
    wukong sun Junior Member
    66
    You need an OBD device to read some data
    Hybrid Assistant: OBD
    If possible, I need these replacement parts, thank you
  18. Mendel Leisk
    41,957
    How's the coolant level in the reservoir? Almost certain to be head gasket failure. Borescope inspect the combustion chambers, looking for, exceptionally clean piston tops (due to coolant), pooling coolant, coolant tears running down from the head gasket seam. The latter will be increased by pressurizing the cooling system, say hooking up a stopper in place of the reservoir cap and applying air pressure. Something like this:
    Professional EGR Cleaning Resources | Page 9 | PriusChat
  19. wukong sun
    66
    The symptoms are very similar to my Prius. The car does not shake when it is cold, but it will rattle once it starts charging the high voltage battery. Even if it is not charging, it will rattle when the engine temperature rises.
  20. Frank MM
    16
    Why do you think it's head gasket failure? It sounds nothing like the death rattle. I have no symptoms of head gasket failure at all that I can detect.
