2012 Prius all lights on issue
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by JimJ2018, Nov 7, 2018.
  1. JimJ2018
    JimJ2018 New Member
    Colorado
    Hi Guys,
    I have a 2012 Prius and only put 29000 mileage on it. Driving was fine till a couple of days ago, cold started the car the next day morning and saw all lights were on and car was not ready. Turned it off and waited for a couple of mins before turning it back on again, the same. After tried a couple of times the car was eventually turned on. Then the car was driving like normal for some days. Today, I was cold starting the car again from home and the problem came back. I have already scheduled a dealer visit but have concern if the car runs fine in the dealer given the problem is sporadic so they can't replicate the problem, then there will be no fix. Hope some one here can give me a clue what I am dealing with. Thank you for any input.
  2. tankyuong
    tankyuong Senior Member
    1,511
    644
    Central MO
    Sounds like you didn’t press the brakes hard enough before pressing the start button
    Raytheeagle likes this.
  3. xliderider
    xliderider Senior Member
    7,498
    2,913
    Honolulu, HI
    Another possibility is that the brake pedal sensor switch is intermittently not working properly.
  4. Eddy Connelly
    Eddy Connelly Member
    37
    27
    New York
    I'd second that it's running in accessory mode. What color is the light on your On switch when this happens?
  5. Usle
    Usle Member
    315
    135
    Me
    2018 Prius Prime
    The brake sensor switch sounds posible, also, I'd trickle chqrge the 12v battery overnight to see if it's possibly a weak or bad 12v battery, 6-7 years is a possibly used up battery.
    xliderider likes this.
Loading...
