1. The site is migrating to a new server this week, so there will likely be some downtime during that process. You can follow along here for updates.
2012 Prius C DISP/TRIP Buttons out
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Prius C dude, Jun 7, 2023.
  1. Prius C dude
    Prius C dude New Member
    Phoenix, AZ
    Hello, I'm new to the Toyota world and have a 12 Prius C type 2.
    i have an issue with my Steering Wheel. I changed out my old crumbling Foam Steering Wheel for a super nice Leather Wheel from a 13 Pruis V. It also came with both L/R buttons, so I installed it and was all excited as it looked super cool, but by doing so I lost the RH side DISP/TRIP buttons. The Temp buttons work fine as does the LH buttons for the Speaker Controls. Not sure why the DISP button is not working? My old wheel all buttons worked just fine...
    1. Button broken?
    2. Not interfacing with the dash?
    3. Does it matter my radio is the standard and this Leather Wheel probably went with the upgraded radio with Nav?
    Went by Toyota and they recommend replacing the RH button switch assy #84244-47110-B0 cost $888.32(yikes!!!). Did find it online new for $500-$600, I really don't want to pay that. So it looks like I'm off to the junkyard, what does anyone recommend? I'm baffled, and I also have no Odometer, Clock, or to be able to run the MPG, etc...
    Thanks for any input
  2. SSAutomotive
    SSAutomotive Junior Member
    Stewartstown, PA
    Remove buttons from old and put on new if possible?
    or
    See if boards can be swapped out within units.
    My money is on bad connection or bad unit. Possible interface issue as you stated.
Loading...
