2012 Prius Won't Go Into Park in the Extreme Cold
Discussion in 'Gen 3 Prius Main Forum' started by bresna, Jan 22, 2019.
  1. bresna
    bresna Active Member
    193
    144
    Southern Maine
    After the storm Sunday here in Maine, it got very cold (~0 F) and we had to shuffle the cars to clear the driveway. After she moved it a little, my daughter's 2012 Prius would not go back into Park. A warning message came on the upper display saying that we needed to move the car to a flat surface (there's a very slight incline on my driveway) and engage the parking brake to press the P button. Well, you can't shift the car in this state either, so I don't know how they expected us to move it anywhere.
    I finally attempted to lock the car as if exiting to see if I could trick the car to shut down and then it started working again.
    It seems like the parking pawl was not engaging/disengaging. Any ideas or should I just bring it into a dealer?
  2. bresna
    193
    144
    Southern Maine
    Adding new info... today (still frigid - ~7 F) when she starts the car, it makes a rapid, loud knocking sound and won't start. Is this the pawl pin going in & out? Are we talking a transmission problem?
    48,862
    start with the 12v health, that kind of cold requires a strong battery
  4. bresna
    193
    144
    Southern Maine
    What's the best 12V battery these days? I remember for my old 2004 Prius, Optima was the recommended battery. I did buy one of them and it worked well. Are they still the best? $220 though... Ouch.
  5. bisco
    48,862
    nothing objective. whatever has worked best personally is what each user recommends.
    i don't think you can go wrong with the best deal available, haven't heard of any major problems.
    #5 bisco, Jan 22, 2019
  6. bisco
    48,862
    just thinking, if the car is starting, it may not be the 12v. i wonder if ice can form somewhere causing a binding problem
  7. bresna
    193
    144
    Southern Maine
    It's not starting at all now. Just making a fast clunking noise when she presses the start button. It sounds like her 7 year old battery is wreaking havoc with her electronics.
    I think I'm going to pick up an O'Reilly Super Start Platinum on the ride home. They have it in stock and I'd really like to install it this weekend.
    I might add that I've read quite a few negative reviews on Amazon for the Optima. Have they gone downhill?
  8. bisco
    48,862
    unfortunately, they've had the ups and downs, some have great experiences, others don't
  9. bresna
    193
    144
    Southern Maine
  10. Grit
    Grit Senior Member
    6,103
    4,032
    Wilkes Land
    Thought the 12v hands the engine start up to the Hv bat?
    bisco and Johnny Cakes like this.
  11. stephensprius
    stephensprius Active Member
    670
    226
    Minneapolis, Minnesota
    we are in minneapolis. never had this issue. interesting to follow.
  12. bisco
    48,862
  13. bisco
    48,862
    agreed, see my post #6, then o/p's post #7
    Johnny Cakes likes this.
  14. Grit
    Grit Senior Member
    6,103
    4,032
    Wilkes Land
    Nope, I need data. Impression of bill norton.
    Raytheeagle likes this.
  15. padroo
    padroo Senior Member
    2,763
    2,250
    The battery may or may not have issues and that needs to be sorted out but cold weather along with snow and ice on metal and moving surfaces may be a problem. I'm thinking condensation, get the car into a heated garage for 24 hours and I bet the parking paw problem goes away.
    If you have never lived up north you wouldn't understand how things just start acting weird on your car below zero.
  16. Grit
    Grit Senior Member
    6,103
    4,032
    Wilkes Land
    Frozen parking paw
  17. bresna
    193
    144
    Southern Maine
    Picked up the Bosch 12V battery from Pep Boys and swapped it in. It only took about 15 minutes. Hardest part was getting the vent tube off the old battery. Car boots up fine and everything seems back to normal. We're expecting another cold snap Thursday, so we'll see if this problem comes back.
    Thanks for the reminder about the 12V battery causing problems. I seem to remember that when it failed in my '04 Prius, all kinds of weird stuff started happening.
    fuzzy1, padroo and Mendel Leisk like this.
  18. ASRDogman
    ASRDogman Senior Member
    5,837
    3,137
    Just make sure the battery has a full charge. Do you have an AGM charger? Or trickle charger?
    Wolverine88 likes this.
  19. bresna
    193
    144
    Southern Maine
    I trickle-charged it before I installed it.
    ASRDogman likes this.
  20. ASRDogman
    5,837
    3,137
    Then you should be good to go! :)
    The man had replaced the battery in the Prius I bought 2 or 3 months before I purchased it.
    So I should be good for at least 4-5 more years. It was a Toyota one and haven't had
    any problems with it.
