2013 Aqua/prius c Brake lines bled now pedal is lower, slip light goes on when press
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Timber Jack, Mar 2, 2026.
  1. Timber Jack
    Timber Jack New Member
    Japan
    2013 Aqua
    Brake lines bled now pedal is lower, softer, easily goes to the floor, slip light goes on when brake is pressed to the floor on level ground. Is this normal?
    52,417
    No, read the trouble codes with a Prius aware scanner
  3. ChapmanF
    18,587
    Your post doesn't describe who 'bled' the brakes or how. The bleed procedure that is programmed into the car requires a suitably-capable scan tool, and doesn't offer a non-scantool alternative method.
    If that isn't how the job was done, you simply need to find a shop with the equipment, or get it yourself, and have it done correctly.
  4. Timber Jack
    Japan
    2013 Aqua
    Thank you, the bleeding of the brakes were done by professionals, not Toyota though, and I am unaware if they used "suitably-capable scan tool". I complianed and was told they bled the brakes three more times but could not explain the difference in the brake feeling.
  5. ChapmanF
    18,587
    I feel for them if they can't "explain the difference in the brake feeling", but if the light comes on, that's more than a difference in "feeling", and you should get the trouble code from that, and then go where somebody knows what to do about it.
    Absent a scan tool, you should be able to get the brake/skid trouble code(s) this way (unless it's different in Japan):
    Blink (a/k/a Flash) Codes – How to. | PriusChat
    Timber Jack and BiomedO1 like this.
  6. BiomedO1
    BiomedO1 Senior Member
    4,217
    2,200
    SacTown, Ca
    Take it to a dealership to get it done CORRECTLY or a Toyota specialty shop. From what your describing, they got air in your brake system or there's a leak.
    Try getting the car in ready mode and holding down the pedal - it shouldn't sink or go down slowly; it should stay firm; without ABS lights.
    The ABS lamp is on because the ABS computer either can't stabilize the pressure in a specific chamber or the people who did the job messed up the rotation sensor. Either way, that shop is responsible and a ABS capable computer will tell you specifically what is setting-off the warning ....o_O
    #6 BiomedO1, Mar 3, 2026
    bisco and Timber Jack like this.
  7. Timber Jack
    Japan
    2013 Aqua
  8. Timber Jack
    Japan
    2013 Aqua
    thank you for the reply. You’re right and that’s what we’re going to do. Take it to a Toyota dealership for inspection.
  9. Cinderblock
    Cinderblock Junior Member
    New Zealand
    i-Tech
    must use tech stream to do the brake bleed. The abs pump does the rear and the front are done manually, also the solenoid gets bled
