2013 Prius c will try to start the gas engine but stop and not go into ready mode.Hybrid batteryLow
Discussion in 'Prius c Main Forum' started by Gerardo, Nov 5, 2017.
Tags:
  1. Gerardo
    Gerardo New Member
    Arizona
    I have a 2013 Prius C that will not stay in ready mode will only for a second try to start has engine because hybrid battery is very low. The car has being park for 8 months
  2. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,317
    Central Virginia
    Are you sure your 12 Volt battery is OK? That is what boots up the computers into READY mode and closes the Hybrid battery switch.
    If the 12 volt battery is low you can get all sorts of strange, false errors.
    Raytheeagle likes this.
    48,945
    you need a grid charger (@jeff652) to charge the hybrid battery, or have a dealer do it.
  4. ChapmanF
    15,072
    It is certainly possible for both batteries to be low after 8 months, and the 12 volt is easy to charge, so I would definitely do that, just for peace of mind.
    That said, could you describe the behavior as clearly as you can? Your subject line says the car will "not go into ready mode" and your post text says it will "not stay in ready mode will only for a second". Which is it? Does the car light the READY light briefly, then give up after an attempt to crank the engine?
    You haven't mentioned the source of your information that the traction battery is low. Does that come from the battery bar graph on the MFD, or some other instrument?
    In any case, after 8 months, you are probably right, and it gets lower and lower with every attempt to start the engine, and it is difficult to charge (special equipment required), so one thing you do not want to do is keep trying over and over.
    In the worst case, you may in fact need to charge the traction battery before the car will start. That may require an appointment at a dealer, though there might be other options depending on your skills and willingness to tangle with lethally high voltage DC.
    If you have a chance to read any trouble codes from the car, I would do that and post them. They are unlikely to be false. The idea that a low 12 volt produces false codes is all over PriusChat, but never (that I have seen) with the four ingredients that would be necessary for an actual example, namely:
    • Car was scanned for codes
    • Codes were looked up in Repair Manual to see what they meant
    • Troubleshooting procedure was followed to check car for the indicated condition(s)
    • The indicated conditions were shown not to exist
    If it is so common for low 12 V to produce false codes, it should be easy to produce such an example and post it on PriusChat, but I've been around here since 2008 and not seen such a posting. I've seen a lot, though, that just throw out "could be false codes because of the 12 V" in advance of anyone checking the possibility that the codes mean what they mean.
    -Chap
    Prodigyplace likes this.
  5. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Sorry but BAD advice.
    He needs to check the 12 V aux. battery first.......or have a dealer do it.
  6. Mendel Leisk
    38,210
    Parked for 8 months? Any steps taken to mothball it, negative battery lead disconnected for example? Or that's all she wrote? If so, almost certainly the 12 volt is dead, and likely not recoverable. Check that first, get it resolved, then go from there.
    Was this outdoors, in a garage? How many miles on it?
    Raytheeagle and Prodigyplace like this.
  7. bisco
    48,945
    thank you, try reading the o/p again, i can only go by the information provided.
  8. Sam Spade
    2,036
    1,023
    2017 Prius c
    He is making an assumption......and you are following right along.
  9. bisco
    48,945
    is he, or are you?
  10. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    I think we all are...
  11. bisco
    48,945
    without the o/p, we're groping in the dark.
  12. Gerardo
    Gerardo New Member
    Arizona
    Update: I charged the 12 volt battery to its fullest and clear all codes. I did make sure the hybrid orange connection is all the way in and pushed in the correct locked position. When I try to start it you hear the relays on the hybrid battery click and the ready light goes on and off. My guts tell me that the hybrid battery are way to low and somehow it will not allow the gas engine to come on. I can see the hybrid battery has only one bar
  13. Gerardo
    Gerardo New Member
    Arizona
  14. Mendel Leisk
    38,210
    On our regular 2010 Prius I've never seen less than 2 bars. Get codes read?
  15. Sam Spade
    2,036
    1,023
    2017 Prius c
    The problem with this report is: You don't know without taking a voltage measurement AFTER the charging and startup attempt whether or not the 12 V battery is actually storing the charge you gave it and is able to give it back.
    I suppose that a REALLY dead hybrid battery could be a problem but......one bar is not "dead" and if it was dead, how did it GET that way.
    The odds still favor a problem with the 12 V battery; more testing is needed.
  16. ericbecky
    ericbecky Hybrid Battery Hero
    4,365
    3,209
    Madison, Wisconsin
    I have a standard procedure for this kind of situation.
    Especially helpful when you don't have any diagnostic tools.
    1) get 12v up to healthy range. Double check that post and ground connections are secure.
    2) remove air cleaner box so you can remove MAF and clean MAF with MAF cleaner
    3) unbolt throttle body and sop up and oil from inside/top of intake
    4) with car off, spray some starter fluid down the throttle body's butterfly.
    5) quickly hop in car and put in Ready mode. The car will try to start gas engine.
    6) quickly hop back out and judiciously spray additional bursts of starter fluid on top of the butterfly to keep car running.
    If car starts to run properly, stop adding starter fluid.
    7) replace air cleaner box
    I just did this with a car that someone had killed the 12v.
    If you really did get the hv battery too low, then you will need to use a high voltage charger to charge up the pack first.
    You won't know the hv battery voltage without diagnostic scanner, or without opening up the pack.
    There are some other more risky/life threatening ways to "jump start" a hv battery if you have a spare Prius. But I would only employ them in an emergency and when I had high voltage safety protection equipment.
  17. Gerardo
    Gerardo New Member
    Arizona
    Update: The hybrid battery was the corporate of all the issues here!!!!! I replace 12 volt and still had issues I thought to myself well than let me change the hybrid battery from my other Prius c into my trouble Prius And what do you know it turn on right away and I drove it around the block. So as someone said before if the battery is bad or low it may give odd functional issues or codes. So my original hybrid battery is either bad or is so low it will not allow the gas engine to come on! A not to all do not let your hybrid battery sit there to long with out turning on the car to charge it! Thank you alll for taking the time to help someone in bad situations. May God Bless you alll!!!!
    bisco and Mendel Leisk like this.
  18. Prodigyplace
    11,696
    11,317
    Central Virginia
    So what is your plan to charge the battery?
    I suspect a Prolong grid charger would work. I would call Hybrid Automotive to verify first though.
    Officially the dealer needs to get in a special charger to charge the traction battery.
  19. Gerardo
    Gerardo New Member
    Arizona
    Thank you all for the information. I will take the bad or depleted hybrids battery and check it with a meter for individual voltage. Never done it so if anyone had a process of testing would be appreciated. Thank you all for taking time out of your valuable time to help anyone!
  20. bisco
    48,945
    it wasn't the 12v? shocking!:p
