2013 Prius Four - 12V Switched Power from HomeLink Mirror
Discussion in 'Gen 3 Prius Accessories and Modifications' started by prius_speed, May 30, 2013.
  1. prius_speed
    prius_speed Junior Member
    San Francisco, California
    Anyone tapped into the HomeLink mirror for powering a Dash Cam or Radar Detector? Don't really want to run wire down the A-beam.
  2. gliderman
    gliderman Active Member
    751
    223
    Yes its very easy. Do a search, there is a thread about how to do it.
  3. prius_speed
  4. prius_speed
    Also, if you short the homelink mirror connection for whatever reason, you'll have to replacethe 10A IGN2 fuse in the driver side compartment. There's a spare in the engine fuse box. Afterwards, disconnect the battery in the trunk (black wire off the BODY of the car, not off the battery. Size 10 bolt). To replace the fuse .. it's a "low profile micro ATM fuse"
    Don't ask...
