2013 Prius Knock and losing coolant but oil looks fine
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ClammyMantis, Dec 1, 2023.
  1. ClammyMantis
    ClammyMantis New Member
    Your Catalytic Converter
    My Prius has been knocking ever since I went on a road trip. I was just working on the oil fearing for the chocolate milk of doom but instead I got the normal vantablack. One interesting thing is that before the knock my oil catch can was black too. Now it's all milky. What does this mean? I'm gonna do a compression test after I finish the oil change and will report back.
  2. Tombukt2
    Tombukt2 Senior Member
    13,484
    2,425
    Durham NC
    What you get in your catch can. Is going to have residual moisture in it The little drips that are coming in cylinder 1 2 3 whatever it is That's causing the rattle as it quenches the fire It's like you got a fire extinguisher built into one of your cylinders Not really ideal when you need the fire to power your engine or make the power your engine needs to make the fire is what it's all about now you're quenching that with drips of coolant coming to your head gasket what you're going to catch in your catch can is that vapor moisture and oil which is what you see I think in the second picture what's in the oil pan will not look like what's in the catch can as you're seeing when you pull your stick It's not like the old days where you have a massive flood coming through the head gasket dropping on top of the piston going past the rings and dropping into the pan and getting stirred up to the coffee light mixture You're used to viewing a long time ago.
  3. Mendel Leisk
    41,948
    What’s the miles?
    I’d ask about EGR and intake manifold cleaning too, but that might be considered “leading the witness”.
  4. ClammyMantis
    It has 204,000 now. I just did a compression test and got the numbers back. First number is without oil in cyl and second is with. And I cleaned the egr at 180,000 iirc
    1. 82 / 115
    2. 90 / 110
    3. 95 / 112
    4. 80 / 125
  5. BiomedO1
    BiomedO1 Senior Member
    4,221
    2,204
    SacTown, Ca
    Just because coolant isn't mixing in your engine oil, does not eliminate the possibility of a blown head gasket.
    If you can borrow a camera (bore-scope) from your local auto parts store, compare the top of cylinders 1&4 to 2&3. The piston tops should all be pitch black with carbon. Any piston top that looks like it's been steam cleaned, has coolant leaking into it. Blown head gasket.
    Good Luck....
  6. ClammyMantis
    2 and 3 did look cleaner than 1 and 4. 1 and 4 were pretty black iirc and on 2 and 3 you could see metal
  7. rjparker
    rjparker Tu Humilde Sirviente
    10,579
    6,636
    Texas Hill Country
    Those pressures are not good, probably because of procedure needed with Techstream. 157-199 psi or more is the min-max. Regardless a borescope inspection is preferred.
    From Manual:
    Warm up engine.
    (a) Put the engine in inspection (Maintenance) mode.*
    (b) Warm up and stop the engine.
    (c) Remove the 4 spark plugs
    Inspect the cylinder compression pressure.
    (1) Insert a compression gauge into the spark plug hole.
    (2) Connect the Techstream to the DLC3.
    (3) Turn the power switch on (IG).
    (4) Turn the Techstream on.
    (5) Enter the following menus: Powertrain / Hybrid Control / Active Test / Compression Test / ON.
    (6) Fully depress the acceleration pedal.
    (7) Depress and hold the brake pedal, and turn the power switch on (READY).
    NOTICE:
    The measurement must be done as quickly as possible.
     Noise may emit from the transmission. However, this is not a malfunction.
     Always use a fully charged battery to obtain an engine speed of 200 rpm or more.
    Standard compression pressure:
    1373 kPa (14.0 kgf/cm2 , 199 psi) or more
    Minimum pressure:
    1079 kPa (11.0 kgf/cm2 , 157 psi)
    Pressure difference between each cylinder:
    98 kPa (1.0 kgf/cm2 , 14.2 psi) or less
    * Inspection (Maintenance) Mode Using Techstream:
    Activating maintenance mode (Using the Techstream)
    Enter following menus: Powertrain / Hybrid Control / Utility / Inspection Mode - 2WD
    Check that "MAINTENANCE MODE" is displayed on the multi-information
    display
    Start the engine by turning the power switch on (READY) while depressing the brake pedal.
    The idle speed in maintenance mode is approximately 1000 rpm with park (P) selected. The engine speed increases to 1500 rpm when the accelerator pedal is depressed midway with park (P) selected. When the accelerator pedal is depressed more than midway, or when the accelerator pedal is fully depressed, the engine
    Do Not Drive in Maintenance Mode!
    #7 rjparker, Dec 2, 2023
    Brian1954 likes this.
  8. rjparker
    10,579
    6,636
    Texas Hill Country
    Borescope Video
    Car Care Nut HG Borescope at 10:57, watch at least through 14:00
    Note cheap borescope with one camera are not able to see the head gasket
  9. ClammyMantis
    I'll have to see if I can rent one with 2 cameras, that would be nice. I found this thread https://priuschat.com/threads/real-life-compression-test-results.169495/ that has a different toyota doc that has compression as 89.5 minimum. One thing I found when using techstream to test was the engine didn't crank for more than 2 seconds. I thought you needed a few seconds of crank until the needle stops moving to get an accurate value.
  10. Mendel Leisk
    41,948
    Try leak down test?
  11. rjparker
    10,579
    6,636
    Texas Hill Country
    The 200 psi readings are at 850 rpm. 150 psi is typical at 250 rpm. Consistent pressures are key at any rpm.
    Compression is not your problem.
  12. ClammyMantis
    Yeah, I ordered a kit and will try monday.
