2013 Prius v *lowercase v for the Prius v wagon........* Front Strut Replacement - Video
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Surfer Dan, Jan 28, 2017.
  1. Surfer Dan
    Surfer Dan New Member
    Murrieta
    2013 Prius v wagon
    I finally got around to changing the front struts on my 2013 Prius v lowercase v for the Prius v wagon, not an uppercase. Only the 2010 Prius used uppercase Roman numerals for model designation. I had 155k miles on the oem struts and they were bad although there were no visible signs of leaking. I was able to easily push them in once they were off of the vehicle. It handles a lot nicer now.
    I made a YouTube video showing the process and thought I should post it here hoping it might be helpful to someone. Here's the link to the video:
    MrJamtastic, jzchen, TheDylan and 4 others like this.
  2. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    655
    262
    Dodge Co. Wisconsin
    2017 Prius v wagon
    Nice job
    Surfer Dan likes this.
  3. milkman44
    milkman44 Active Member
    591
    386
    Ky
    Thanks, just watched the video. Which struts did you use, I will look for something besides KYBs.
  4. Surfer Dan
    Murrieta
    2013 Prius v wagon
    Sorry for the late reply, I used the Monroe OESpectrum struts and just did the rear shocks with the same brand. I am happy with the way it drives and handles now.
  5. Surfer Dan
    Murrieta
    2013 Prius v wagon
    I just finished replacing the rear shocks on my 2013 Prius v lowercase v for the Prius v wagon, not an uppercase. Only the 2010 Prius used uppercase Roman numerals for model designation. I had 159k miles on the oem shocks. I used the Monroe OESpectrum rear shocks and they ride nicely. A little stiffer in the back than I expected, but it's not bad. Since I already posted a video on here of the front strut replacement, I thought I should post the rear shock replacement video as well. Here's the link:
    jzchen and Aaron Vitolins like this.
  6. Air_Boss
    Air_Boss Senior Member
    3,913
    1,068
    New Yawk
    Nicely done.
  7. milkman44
    591
    386
    Ky
    Nice video, thanks, if only the fronts were that easy.
  8. 12n14V
    12n14V New Member
    SD CA
    Rear factory KYB Shock failure: At 107 K miles our r r fact. KYB failed noticed oil covering complete shock... did KYB replacement shocks...easy as pie / 30 min R & R replacement. Took longer to find best deal on internet $79 PP tax incl in 3 days from C*r*d or $108 @ your local parts dept overnight or same day
  9. 12n14V
    12n14V New Member
    SD CA
    Radio Tuner inop.: Re 2012 Prius v radio (panasonic) model 57011on faceplate (every option, Sirus & HD, Nav. CD except no JBL) Problem: the manual station tuning knob issue: Internal failure:seems that if you have a tuning knob it jumps up and down as you spin it... it has a "encoder failure. It will not effect other features of the radio. So if you can put up with just using scan and then preset the station you want - you don't have to fix it and you can live with a finicky knob tuner. Or spend 30 min and pay 300 to have it fixed or buy used replacement (same model number) on internet for less.
  10. ♡myPeeus
    ♡myPeeus Junior Member
    61
    57
    US
    Out the front door! Damn a girl can do this! Thank You! Now how are the front struts done on a 2008? Are they in the same area of the front of the car? Cause i was quoted 1,000 for front. I feel so educated. Heeee :)
  11. ♡myPeeus
    61
    57
    US
    Dont scare me. Thats one thing needing done on mine
  12. belbert@metrocast.net
    [email protected] Junior Member
    17
    @Surfer Dan--used your video today and it made teh job super easy. Much appreciated. Thanks for the Happy New Year Day!
  13. jzchen
    jzchen Newbie!
    3,296
    1,006
    Arcadia, CA
    I ended up getting the full complete strut, part #172682, (cough, for my Scion tC). Just curious if you noticed the strut body etched with "Made in Japan"? I also ordered the upper mount part #906989 that is for the Prius v. Without pulling the strut apart I tried to see if the two pieces with metal plates would fit the shaft and they appear to be too narrow. Comparing with the Scion tC upper mount part #906987 they are not equivalent parts! KYB sells the exact same strut for both tC and Prius v.
    I guess I'll go try to install the 172682 on my, (cough), tC now.......
    moto g(7) power ?
