Discussion in 'Newbie Forum' started by Al h, Nov 7, 2021.
  1. Al h
    Al h Junior Member
    35
    Nj
    Hello,
    I have a 2013 Prius. It has 2 codes:
    P0455 & P0441.
    Any idea/help is appreciated-thx.
    52,390
    make sure the gas cap is tight
  3. Al h
    Al h Junior Member
    35
    Nj
    I did, don’t think that’s the issue. Any other suggestions?
    Thx.
  4. rjparker
    rjparker Tu Humilde Sirviente
    10,504
    6,594
    Texas Hill Country
    Big leak in the evap system. Do you smell gas in the back or at the engine? Visually inspect.
  5. Al h
    Al h Junior Member
    35
    Nj
    Not sure. I’ll drive it and try to see if I smell any gas.
  6. Al h
    Al h Junior Member
    35
    Nj
    So I smell gas from the back.
  7. rjparker
    10,504
    6,594
    Texas Hill Country
    Be sure the gas cap is clicked on. Next step is a shop with a lift to find the leak. Probably a vapor hose.
  8. Al h
    Al h Junior Member
    35
    Nj
    I actually replaced the gas cap which I got from Autozone and probably drove for about 80 miles in total or so, but the check engine light never turned off and I had the same two codes even after replacing the gas cap with a new one from Autozone.
    P0455 &
    P0441
  9. Al h
    Al h Junior Member
    35
    Nj
    Am I supposed to clear the codes? Or will it clear on its own?
    Also do you think perhaps the gas cap from Autozone is not the exact fit so that’s why the codes remain?
    Thanks in advance.
  10. bisco
    52,390
    i think you have to cycle the car (drive it) a certain amount of times to clear the codes.
    autozone gas cap could be a problem, just depends on the design.
  11. Al h
    Al h Junior Member
    35
    Nj
    Do I need to clear the codes though? Or they’ll clear on their own after driving for awhile assuming the gas cap is the issue?
  12. bisco
    52,390
    not sure if they will clear on their own. if the light goes off, see if they are still there.
  13. Al h
    Al h Junior Member
    35
    Nj
    So I probably drove 90-100 miles already with the new cap and no change or clear codes.
  14. bisco
    52,390
    how many drive cycles have you done? was the old cap bad in some way?
  15. Al h
    Al h Junior Member
    35
    Nj
    Drive cycles? You mean how many times did I turn the car on and off???
  16. Al h
    Al h Junior Member
    35
    Nj
    Probably 4/5 times
  17. Al h
    Al h Junior Member
    35
    Nj
    4/5 times within the 90-100 miles I’ve driven after replacing the gas cap
  18. bisco
    52,390
    starting to sound like the evap system
  19. Al h
    Al h Junior Member
    35
    Nj
    Yup, rjparker on this thread is suggesting the same thing. So I guess that can literally mean anything from the canister to the hoses, etc.
  20. bisco
    52,390
    what code reader are you using? idk if tech stream and/or the service manual can help nail it down or not
