2014 Prius c Radiator Fan Won’t Shut down
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by crxnug, Oct 8, 2021.
  1. crxnug
    crxnug Junior Member
    dunnville ontario
    2014 Prius c
    I have a 2014 Prius c , The problem i having is radiator fan wont turn off unless i turn the car off, my question is what can be the cause, If its a sensor does anyone have a picture of the location, Any help would be much appreciated
  2. Sonic_TH
    Sonic_TH Active Member
    513
    81
    Puerto Rico
    Sorry for the late reply. It could be a relay, do not know if you have checked that already but if you have not, you should start there, with the relays. Replace them, if the problem persists, try replacing the fan control unit which is on top of the fan by the radiator.
