2015 Prius For Sale - Heavily Upgraded
Discussion in 'Prius Cars For Sale' started by travisjb, May 28, 2020.
  1. travisjb
    travisjb Junior Member
    NC
    ASKING $10,000... local pickup only in Greensboro, NC
    2015 Prius Four ZVW30
    Approx. 132,000 miles
    Second owner w/ clear title
    Smart Key entry system
    Auto on/off headlamps
    Auto climate control
    Cruise Control
    Perfect service record
    One minor accident front end, professionally repaired w records available
    Heavily modified! Rides on rails! Likely the fastest Prius in NC :)
    WHEELS / TIRES
    16X7 ENKEI PERFORMANCE DRACO ANTHRACITE
    215/50R-16 DUNLOP DIREZZA DZ102 SL (~4,000 miles)
    4-wheel alignment with specs as follows
    FRONT camber between -1.0 and -1.2 degrees
    FRONT toe between 1/16" and 1/8" total toe OUT (both sides 0"+)
    REAR camber between -0.8 and -1.0 degrees
    REAR toe between 0" and 1/16" total toe OUT (both sides 0"+)
    SUSPENSION / CHASSIS
    TEIN Flex Z Coilovers VSQ08-C1AS3
    Tanabe Front Sway Bar
    Progress Group® - Rear Anti-Sway Bar
    Cusco 951 540 ALHD - Front Type OS Strut Tower Brace
    Cusco 952 492 REN - Rear Power Brace
    Cusco Front Lower Arm Bar Type I ZVW30
    Cusco Center Power Brace ZVW30
    Cusco Front Center Power Brace ZVW30
    SPC Front and Rear Camber Bolts
    ARP® 100-7719 - Wheel Stud Kit
    New brake rotors and pads (<4,000 miles)
    INTERIOR
    Weathertech mats and cargo liner
    Full LED interior light replacement kit
    Rear Hatch Trunk Luggage LED Lamps for 2010-2015 Toyota Prius
    Stainless Steel Transmassion Shift Gate Panel Cover Molding
    Smabee Car Central console Box storage Interior Accessories Box Coin storage BLACK
    Max Legal NC window tinting professionally installed
    ELECTRONICS
    DSP IPS 4G 64G Android 9.0 Radio GPS For Prius DVD Player 8 CORE Nav Stereo Multimedia Head Unit w/ rear camera
    Rockford Fosgate P300-12 Punch 300 Watt Powered 12-Inch Enclosure w/ remote
    Beat-Sonic FDA51-070 Blizzard Pearl Functional Shark Fin Antenna
    FalconZero F170HD+ DashCam 1080P 170° Viewing
    LED low beams 6000K
    LED high beams 6000K
    LED Brake Lamps, Turn Signal, Driving Lights, Rear License
    8-Pin Electronic LED Flasher Assy Relay Fix
    PERFORMANCE / OTHER
    K&N PS-7021 Pro-Series Oil Filter
    Quick release oil pan drain EZ (L-001) Silver Small 90 Degree Hose End EZ Oil Drain Valve
    Rear windshield wiper delete
    #1 travisjb, May 28, 2020
    SFO likes this.
  2. travisjb
    NC
    Reduced to $9,000
    Kelly Blue Book Private Party Value = $8,657 (stock, great condition)
    SFO likes this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    3,072
    3,581
    Columbia, SC
    Out of curiosity, what are you basing this on? Aren't they all computer mph limited?
  4. travisjb
    NC
    Sorry I'm not a 0-60, quarter mile or top end speed guy... Was referring to time from point a to point b with turns involved... this car corners like a 2,500 pound racecar
    #4 travisjb, May 29, 2020
  5. TMR-JWAP
    3,072
    3,581
    Columbia, SC
    So you race this car in SCCA or similar?
  6. travisjb
    NC
    No sir, and not aware of an SCCA series involving Prii but that sure would be amusing. I raced w NASA in a Porsche Boxster and a Nissan 370Z. This Prius has been my commute car for the last few years. Keeps me out of trouble with the law. In fact, have never been pulled over in this one.
  7. travisjb
    NC
    Price reduced again... $8,500
    SFO likes this.
  8. Montgomery
    Montgomery Senior Member
    1,709
    1,740
    Orange County, CA
    Pictures sir, you need to load up pictures.............:)
    geedub likes this.
  9. travisjb
    NC
    Should be 31 pictures in the top most link (IMGUR). Let me know if that's not working for you? Maybe a block on your browser?
  10. Montgomery
    1,709
    1,740
    Orange County, CA
    Ooops, didn't see the little white arrow!! It all there. You loaded it up right. And the car is beautiful!!
  11. travisjb
    NC
    ^ thank you! so much fun to drive... really hoping the buyer gives a shit about all the work I've done :/
  12. ih8philly
    ih8philly New Member
    NC
    How is the ride quality with the Teins?
  13. travisjb
    NC
    ^ All depends upon what you're used to. I believe the spring rate is around 220 pounds per inch but with the short lever arm to wheel, the "wheel rate" is fairly stiff vs how 220 pounds would feel on other cars.
    I don't advocate this reseller but you can see specs here TEIN VSQ08-C1AS3 | TEIN FLEX Z Coilover Kit Toyota Prius G, S, L ZVW30 FF 2009.05-2011.12 JPN
    They are 1-way adjustable so you can dial in a bit of softness through the dampers to soften up the ride a little. Some comparisons:
    Softer than my old race car by far (800 lb springs)
    Softer than BMW m3 F80
    About the same as BMW 2012 135
    Slightly stiffer than Porsche Macan S
    Stiffer than Audi A7 by a good amount
    Stiffer than stock Prius by a LOT
    It's tight enough that there is no slack when shifting weight on the car or at least I can barely notice it... but loose enough to soak up mid corner bumps. Also loose enough that your teeth won't fall out if you hit a speed bump too fast. I was commuting with this from NC to Atlanta for a year and it was fantastic on the highway... only a few stretches where there where potholes and parts of SC w construction. Driving around town in NC, it’s fantastic everywhere except where potholes and speedbumps. Overall, I think this is perfect for the vehicle if you enjoy a more planted feel and want to corner at speed. If anything, I think the kit could be even stiffer in the rear. Maybe a 350lb spring rate instead of 220lb. I also have a lot of other suspension gear on this car that increases lateral and front/rear stiffness. A heavier front sway than stock and a rear sway bar where none exists stock. All of those combine to create a much more BMW like feel to the car and they keep the tires in an optimal angle for traction in corners.
    That help?
    #13 travisjb, Jun 5, 2020
  14. Prius4Lyfe
    Prius4Lyfe New Member
    Illinois
    Return it back to Stock. Then sell the aftermarket parts separately.
Loading...
